Old 01-04-2015, 10:16 AM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
To bag or not!
I have a simple question. I'm thinking about converting to "Air bags" for my '70. My question is, do the "bags" make for an improvement in ride quality? I'm not interested in adjusting ride heights, just making everyday ride less bumpy. My suspension was fully rebuilt about 2 yrs. ago, with new Monroe gas shocks all around about 6 mo. ago. It still rides like a "truck". Yes, I know it IS a truck, but my almost 70 bones are taking a beating. So, is it worth the money to convert to "bags"?
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 01-04-2015, 10:54 AM   #2
mixermike
mixermike's Avatar
Re: To bag or not!
YES....I bagged my 72 and very happy with it. Just for the ride it was well worth the investment . I am currently acquiring parts to bag my 63. Once you drive a properly set up bagged truck everything else rides like crap!! IMHO...I'm 58
mixermike is offline   Reply With Quote
Old 01-04-2015, 11:23 AM   #3
4oldcars
4oldcars's Avatar
Re: To bag or not!
I bought my 71 already bagged. This is my 4th 67-72. Bags are not for me. I like to cruise low profile. You can't cruise with the bags deflated. I removed the bags and went back to original suspension. Much happier. Maybe just me, but I've got a nearly new set of bags on the shelf in my garage that I will never use.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 01-04-2015, 11:50 AM   #4
tcrist
Re: To bag or not!
Sure you can. I had a 1960 Caddy that had "Air Ride Suspension". It would lower itself to the ground when not in use.
When you fire the car up, the compressor would start and raise the car to ride height.
Within an hour or so after shutting the car off it would bleed itself off and lower right back to the ground. There also was a dial & gauge inside of the car to set the max air pressure.
Good way to keep your vehicle from being towed or your tires and rims stolen also.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 01-04-2015, 12:24 PM   #5
72MARIO
72MARIO's Avatar
Re: To bag or not!
I bagged our 1968 Suburban. I hated it because I had a pressure based system for ride height adjustment. Trying to get the alignment set was impossible.
If your going to bag your truck I would highly recommend a air management system like Accuair with a ride height sensor.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-04-2015, 12:29 PM   #6
Pro Performance
Pro Performance's Avatar
Re: To bag or not!
In a properly setup air suspension, it will ride smoother. I think you will definitely see an improvement. The height sensors are a great add on, if budget allows. As mentioned, it does help with alignment. It also makes the system work very simply. Not to say setting the ride height by pressure is bad, as we have many customers go this route as well. If you would like, give me a call Monday and would be glad to help you out and also discuss further in detail, of your options.
Travis
Pro Performance is offline   Reply With Quote
Old 01-04-2015, 12:30 PM   #7
72MARIO
72MARIO's Avatar
Re: To bag or not!
Simple clean operating system.
Thread Tools
Display Modes
