Old 01-06-2015, 12:43 PM   #1
1tuff71
1tuff71's Avatar
sloppy auto shifter
Not sure this is in the right section but here goes. I have a sloppy auto trans shifter and would like to know whats worn out in the column that would cause this and whats the fix. Its kinda scary when I put in park and it feels like it could drop into reverse just from the vibration of the engine.
1tuff71 is offline   Reply With Quote
Old 01-07-2015, 11:27 AM   #2
1tuff71
1tuff71's Avatar
Re: sloppy auto shifter
WOW.Not one response here. Has no one ever worked on their column before ???? Really guys !!??
Old 01-07-2015, 12:08 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I could be that having the post in the suspension forum might not be the best place for answers about the column shifter problem.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-07-2015, 02:09 PM   #4
SeventyOne
Sounds like you have really worn detents. When you pull the lever forward and then down to go into reverse there is a notch on the bottom of the column you are skipping over. On a good column you can't just move the shifter from P to R without that pulling motion (unlike going from 2 to 1, etc).
So, engine off / wheels chocked, get in your engine compartment and have someone pull the shifter like they're going from P to R and find the notch that is the detent. You will probably have to pull the column and maybe its badly rounded. Not sure on if they remake the parts or if you'll have to swap in a good one from another column or if you can reweld to make it good again.
SeventyOne is offline   Reply With Quote
Old 01-07-2015, 05:20 PM   #5
1tuff71
1tuff71's Avatar
Would it be better to have the column rebuilt ?
Old 01-07-2015, 05:37 PM   #6
SeventyOne
Could be a nice time to upgrade to tilt if you don't have one. But first make sure the detents are the problem.
You say it "feels like" it could go from P to R without you moving the shifter. But does it? To test the detent just try pulling the shifter down from P to R without pulling it forward. Pulling it forward lets the column skip the detent so if it moved down without that pulling motion you have a problem. You can even test this without the engine running. Then I would do it with the engine running and your foot on the brake. If it doesn't actually move past the detent thats not your problem.
I would also test R to N. Theres another detent there.
Thread Tools
Display Modes
