01-10-2015, 11:59 AM | #1 |
Radiator hose
Hey guys , can someone give me a part # for the upper radiator hose that I need ? Want to replace this "flex hose" with a nice new smooth hose.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
01-10-2015, 12:09 PM | #2 |
Re: Radiator hose
I am sure someone will pop in with the number.
I have a nice, smooth, molded NAPA hose, that I must have trimmed the length, as there is no number.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
01-10-2015, 02:17 PM | #3 |
Re: Radiator hose
try a napa NBH-7240 for upper and NBH-7438 for lower. both will need trimming
01-10-2015, 02:41 PM | #4 |
Re: Radiator hose
Thank you
01-10-2015, 03:00 PM | #5 |
Re: Radiator hose
There are Gates # in my build thread towards the middle.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
01-10-2015, 03:55 PM | #6 |
Re: Radiator hose
Anyone have a Dayco cross reference ? The napco store closed . Pep boys sells dayco and they can't cross reference
01-10-2015, 04:16 PM | #7 |
Re: Radiator hose
Maybe add some bling ...
01-10-2015, 05:31 PM | #8 |
Re: Radiator hose
At my computer, here are the hoses I used. My radiator is in stock 6 cylinder location, engine in V8 location. I attached photos, can't see all the lower, it goes down to clear the fan belts then straight back to the radiator..
The upper is a Gates 20416, I had to shorten the end that goes on the radiator. The lower is a Gates 20584, I had to shorten the radiator end on it too. The applications are not GM, I took in a bent wire and diameters. I got them at oreilys.
01-10-2015, 05:51 PM | #9 |
Re: Radiator hose
^ thanks for the info guys ! Those fancy hoses won't work for me , shortest one is 20" my upper hose is 14.5 inches. A nice smooth black hose is all I want. That flex hose looks like something to attach to a washing machine LOL
01-10-2015, 05:54 PM | #10 |
Re: Radiator hose
Air cleaner.
01-10-2015, 06:20 PM | #11 |
Re: Radiator hose
The 20416 fits a lot of different rigs so it should be in stock. Each rig having it's own cut here/cut there requirements.
The 20242 is the lower for a car but it looks too short. Take a look at a 20345 lower hose and see what you think.
01-10-2015, 06:50 PM | #12 |
Re: Radiator hose
My lower hose
01-10-2015, 09:30 PM | #13 | |
Re: Radiator hose
your exhaust manifolds look great, are they new ones or old ones cleaned up?
01-10-2015, 11:07 PM | #14 |
Re: Radiator hose
Original ramshorns, cleaned and coated with POR "cast iron" hi temp coating.
01-11-2015, 12:08 PM | #15 |
Re: Radiator hose
^ very nice
01-11-2015, 03:13 PM | #16 |
Re: Radiator hose
if nothing fits your application you can do like an ogre does
buy a 45* ss exhaust tube and use rubber couplers on each end i couldn't find a hose to go around my air cleaner and back to the stock neck lmc and brothers only sell the convoluted hose, though i called both to confirm it was smooth they both sent the convoluted not a fan of the chrome hose covers either also did my lower hose this way with my fan temp sensor in the lower hose
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-11-2015, 03:18 PM | #17 |
Re: Radiator hose
01-11-2015, 03:28 PM | #18 |
Re: Radiator hose
Ogre, that looks slick the way you did that . I'm gonna keep mine the way it is, just want to replace the ribbed hose with a smooth one .probably swap the water neck for a chrome one and stick with the one that points straight towards the front
01-11-2015, 03:44 PM | #19 | |
Re: Radiator hose
01-11-2015, 05:13 PM | #20 |
Re: Radiator hose
Passed by an autozone ... They cross referenced the gates # . Got a nice hose that will work for the upper. Nothing in stock for my lower.
01-11-2015, 05:41 PM | #21 |
Re: Radiator hose
Nice . Upper hose swapped . Decided to swap the hose quick and save the water neck swap for another day . The is a dayco 70344 trimmed at both ends
01-11-2015, 06:08 PM | #22 |
Re: Radiator hose
Much improved over the flex hose.
01-11-2015, 07:15 PM | #23 |
Re: Radiator hose
Thank you. Yea it looks a lot nicer
11-10-2015, 10:21 PM | #24 |
Re: Radiator hose
11-11-2015, 03:50 PM | #25 |
Re: Radiator hose
In a thread on the HAMB someone suggested using a length of cardboard defroster hose or the metalized heat to air cleaner tube to get the shape of the hose so you can go hose hunting at the parts house.
A lots of time on an upper hose you might be needing to take the section out of the middle of a longer hose the right diameter with several bends in it.
Thread Tools | |
Display Modes | |
