Old 01-10-2015, 12:38 PM   #1
of13swc
Chevy 12 bolt rear pinion yolk question?
I am in need of a rear pinion yolk for my 12 bolt 30 spline. Where can I get one for a good price or what vehicles have a 12 bolt that I can take one from (in a salvage yard not steel)? Or will and other rear end yolk work?
of13swc is offline   Reply With Quote
Old 01-10-2015, 04:40 PM   #2
PGSigns
PGSigns's Avatar
Re: Chevy 12 bolt rear pinion yolk question?
Any truck 12 bolt from 64 to I think 81 some where in there they went 10 bolt.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-10-2015, 05:13 PM   #3
of13swc
So a 12 bolt is a 12 bolt pretty much. Just pulled one out of a Chevy truck unsure of year but it had a 12 bolt. It will work correct?
Old 01-10-2015, 09:11 PM   #4
Snailed
Snailed's Avatar
Jimmy
The 12 bolt went to '87 in the trucks
I'm pretty sure that anyone will work. I would count the splines on the one you grabbed, but if it had 12bolts you're probably fine.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 01-10-2015, 10:36 PM   #5
Snailed
Snailed's Avatar
Turns out there could be three different u-joint sizes on a 12 bolt yoke; 3R, 1310 & 1330 A conversion joint could make it work if yours doesn't happen to match your driveshaft.
Old 01-11-2015, 01:30 AM   #6
Captainfab
60-66 Nut
The truck 12 bolt was used from '63-'82. I don't remember if the '63 and '64's had a different spline on the yoke or not. I believe the rest were all 30 spline.
Old 01-11-2015, 09:34 AM   #7
Snailed
Snailed's Avatar
Sorry, yes 1982 seems accurate.
I was looking at the fitment of some of the 12bolt parts I just bought for mine and they listed 1987 as the cut off....not the first time a parts catalog had bad info. Sorry again.
Thread Tools
Display Modes
