Old 01-12-2015, 11:29 PM   #1
mattwhiteyanks1
brake line identification help
I got my brake linespecially in from CPP. No diagram. No labels. Nothing. Can anyone help? I know the two on the right go to the master cylinder but I'm not certain from there. Nothing I've tried seems to fit quite right
mattwhiteyanks1 is offline   Reply With Quote
Old 01-12-2015, 11:52 PM   #2
michael bustamante
michael bustamante's Avatar
Re: brake line identification help
The line next to the master cyl lines goes along the crossmember. That sharp curve is wher the line wraps to the outside of the frame
1967custom
michael bustamante is offline   Reply With Quote
Old 01-12-2015, 11:54 PM   #3
michael bustamante
Did you order 71-72 disk brake lines or 73+? Also do you still have you brake line retainers?
1967custom
Old 01-12-2015, 11:54 PM   #4
mattwhiteyanks1
Alright we'll give it a shot. It's just occurred b to me, I don't believe I have banjo bolts and the soft lines only came with 1 clip each. I need two. One top. And one bottom
Old 01-13-2015, 12:00 AM   #5
mattwhiteyanks1
Well I guess this is right but I don't like it.
Old 01-13-2015, 12:02 AM   #6
mattwhiteyanks1
Easier to see right side up I guess
Old 01-13-2015, 01:32 PM   #7
michael bustamante
yup thats right. it links to the rear brakes. there should be another one that goes along the same route that links to your front brakes. they will most likely route under the engine stands
1967custom
Old 01-13-2015, 01:37 PM   #8
michael bustamante
pm me a reminder and ill e mail you a pic of my routed lines
1967custom
Old 01-13-2015, 10:44 PM   #9
michael bustamante
Heres driver side
1967custom
Old 01-13-2015, 10:53 PM   #10
michael bustamante
Heres driver side
1967custom
Old 01-13-2015, 10:54 PM   #11
michael bustamante
Front
1967custom
Old 01-13-2015, 10:56 PM   #12
michael bustamante
Passenger side you can see where the line goes to the rear brakes
1967custom
Old 01-15-2015, 03:39 PM   #13
michael bustamante
did these help you out any?
1967custom
Old 01-15-2015, 04:10 PM   #14
mattwhiteyanks1
Yeah, these helped a lot. I've actually just decided to bend my own lines. The prebent lines just don't work out like I want them. Thanks for the help
Old 01-15-2015, 04:13 PM   #15
michael bustamante
i hear that alot! i pulled a set from a 72 half ton and copied those
1967custom
Old 01-15-2015, 04:18 PM   #16
mattwhiteyanks1
I'm using the S.U.R&R brake line kit. Their products are top notch and, there's no comparison when it comes to ease of installation. Easy to bend by hand. Won't kink. I've been finishing up my radiator support and dual fan set up the last day or two.
Thread Tools
Display Modes
