Old 01-21-2015, 02:30 PM   #1
1moretoy
9" rear end
Has anyone here bought and installed the 9" housing from Speedway Motors for our trucks. It says the housing measures 62" overall with the axles installed. What are your thoughts using this.
Thank you,
1moretoy is offline   Reply With Quote
Old 01-21-2015, 03:03 PM   #2
davepl
davepl's Avatar
Re: 9" rear end
Well, what does your current axle measure?
I've replaced 12-bolts with 9-inch, and one wheel is offset about a half an inch on the 12-bolt, which it won't be with the 9-inch, but GM didn't account for it anyway. Only really matters if you're marginal on tire clearance to begin with.
Not sure why this is, though the Ford uses a pinion with a support bearing on its nose, don't think a lack of that'd push it one way or the other.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-21-2015, 03:29 PM   #3
1moretoy
Re: 9" rear end
Here is the link
http://www.speedwaymotors.com/Bolt-I...cks,80935.html
Old 01-22-2015, 12:26 PM   #4
1moretoy
Re: 9" rear end
Originally Posted by 1moretoy View Post
Anyone have any input on this.
Old 01-22-2015, 01:37 PM   #5
RodnRudy
RodnRudy's Avatar
Re: 9" rear end
My 68 truck's rear end measures 62" axle flange to axle flange. I just got a 71 rear end which is 1 1/2" wider so I'd have more wiggle room for rear wheel/tire back spacing. Also it is 5 lug. You can end up with a pretty pricey rear if you go with the 9". You'll have axles, backing plates, brake kit and drums. And a rebuilt center section will run around $500.00. I used a Moser 9" In my last truck, a 49 Ford F1 It ended up being around $1500.00 but that's what I wanted.
I guess the question is why do you want to use a 9"? Are you going to drag race it?
RodnRudy is offline   Reply With Quote
Old 01-24-2015, 07:04 PM   #6
1moretoy
Re: 9" rear end
Well I bit the bullet and ordered the 9" housing It should arrive Monday. I plan on narrowing it 4" on each side. I'll let you guys know how the install goes Monday night
If you are looking for a deeper dish look on your rims you will want a narrower rear end not wider. Doing a 9" so when I eventually turn up the boost on the turbo and put in a bigger stall converter I won't have to worry about breaking anything. Not saying I won't but it will be stronger then the 12bolt.
Old 01-24-2015, 09:05 PM   #7
Heavymetl
Re: 9" rear end
I'm doing a turbo LS build as well and considering the same speedway rear.
Any updates to this thread would be appreciated!
Heavymetl is offline   Reply With Quote
Old 01-25-2015, 05:07 PM   #8
Redline novdog
Redline novdog's Avatar
Re: 9" rear end
I don't get it. it is a truck why not use the 14 bolt? Way cheap and bullet proof. If your going full out drag racing, then maybe a 9" .Ford sucks!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-26-2015, 05:32 PM   #9
1moretoy
Re: 9" rear end
Well I received the housing today from Speedway Motors. I put the housing on jack stands and with one of the trailing arm perches at Zero with a degree finder the other is off by three degrees. I don't think that will be ok. I called speedway and they are sending me a new one tomorrow. Hopefully they check it before it leaves so I don't have to do this again. I'll keep you guys updated when the new one arrives.
Old 01-26-2015, 05:38 PM   #10
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: 9" rear end
Good catch...
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 01-27-2015, 01:50 AM   #11
Ozzy2013
Ozzy2013's Avatar
Re: 9" rear end
14 bolt is a 8 lug rear
Ozzy2013 is offline   Reply With Quote
Old 01-27-2015, 07:22 AM   #12
Redline novdog
Re: 9" rear end
U can get 6 lug hubs for a 14 bolt. If need be you can also get them made to change the wms to wms to a certain extent.
Old 01-27-2015, 01:51 PM   #13
SeniorVerde
SeniorVerde's Avatar
Re: 9" rear end
I've got an older mustang 9" rear mocked in a 71 stepside. I considered the Speedway unit, and am curious as to how your project goes.
I haven't torn into my 9" yet and the Speedway unit is still in the back of my mind.
SeniorVerde is offline   Reply With Quote
Old 01-27-2015, 08:28 PM   #14
Ozzy2013
Ozzy2013's Avatar
Re: 9" rear end
The 6 lug hubs are 500+ is the only problem .
Old 01-27-2015, 08:32 PM   #15
kxmotox247
kxmotox247's Avatar
Re: 9" rear end
I found a complete Ford 31 spline 3:50 Traction Lock rear from a 79 f150 for $350. It cost $65 for new axle seats from CPP. $150 to narrow the housing and shorten/respline the axles and redrill the bolt pattern. I had the center section disassembled and cleaned with new bearings for $90. The clutches looked new.
It can be done much cheaper if you're willing to work with some used stuff. I probably could have re-used my driveshaft with a bastard u-joint but I had a new one made for around $200.
kxmotox247 is offline   Reply With Quote
Old 01-27-2015, 08:34 PM   #16
Ozzy2013
Ozzy2013's Avatar
Re: 9" rear end
Wow thats a decent price ill have to call the wrecking yards around here .
Old 01-27-2015, 09:57 PM   #17
kxmotox247
kxmotox247's Avatar
Re: 9" rear end
Check craigslist around your area. That's where I found mine and it was on there for awhile. I was surprised that it hadn't been sold already.
Old 01-27-2015, 10:33 PM   #18
Mock1
Re: 9" rear end
Just curious, and dont get me wrong here but why didn't you look into an explorer rear end?
Factory 31 spline axles, disc brakes, 8.8 ring, 3:55 and 3:73 with factory locker. And if you were planing on cutting a housing down anyway, I think the 8.8 is 56-57"? Also the 8.8 looks just like the twelve bolt on the inside, they already make c clip eliminators for them.
Some of the Hot Rod Drag Week cars use this rear end with turbo Ls power plants. Just curious.
I just gotta get out here and do it, why?
Cause nobody will do it for me...
Mock1 is offline   Reply With Quote
Old 01-28-2015, 02:33 PM   #19
1moretoy
Re: 9" rear end
Well I got a call this morning from Speedway with some bad news. The guys looked at the rear ends they have in stock and apparently they are all the same as what I ended up with. Is there anyone on here that has a stock 12 bolt out of their truck that can check the stock perches for me? I would but I sold mine already . I'm pretty sure they should be the same on both sides.
Thank you,
Old 01-29-2015, 04:31 AM   #20
Ozzy2013
Ozzy2013's Avatar
Re: 9" rear end
Any specific years on the explorer rears?So these should hold up to a 500hp big block?Thanks for any info.
Old 01-29-2015, 06:12 AM   #21
Mock1
Re: 9" rear end
Im thinkin 99 and up. Ill look into it a little more. I think I found a thread on a s10 forum about it. If memory serves right, the only thing after market that was added was an aluminum cover plate. Ill find that thread in a bit. I was lookin to do this swap, but I had a 9" i needed to do something with.
Oh, look for the tag on the diff cover, the one you want should come from a v8 with a "L" between the gear ratio... ( 3 L 55 ) ( 3 L 73 )
That means it has a locker.
Old 01-29-2015, 06:26 AM   #22
Mock1
Re: 9" rear end
http://www.hotrod.com/how-to/transmi...ord-rear-axle/
Heres one from hot rod magazine. It says 91-01.
Old 01-29-2015, 06:46 AM   #23
Ozzy2013
Ozzy2013's Avatar
Re: 9" rear end
Thank you!I have a 68 step side and im putting a 402 Big block and a 5 speed in cant wait should be a sweet ride .
Thread Tools
Display Modes
