01-21-2015, 08:13 PM | #1 |
Vented gas cap for 1972
Does anyone know of a vented gas cap that will fit the smaller gas tank neck of the 71-72 years?
I did away with the evaporated emission system on my build, used an early model gas tank sending unit that only had the one tube, only to find out the stock vented gas cap from the earlier models don't fit the smaller later model necks. I did a search on here but nothing popped up..
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
01-22-2015, 09:02 AM | #2 |
Re: Vented gas cap for 1972
I vented my 71 cap by drilling out the check valve on the inside of the cap. Thought it was a great idea till I took a hard right turn.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
01-22-2015, 06:55 PM | #3 |
Yea..that is what I don't want to happen.
01-22-2015, 07:30 PM | #4 |
I am going to install a later style canister and use a non vented cap. BTW the new NAPA non vented cap lasted one year before the seal split in half ? Overseas crap rubber again
71 C-20 07 Magnum RT AWD |
01-22-2015, 07:50 PM | #5 |
I always just dumped the cannisters and left the tubing there to vent the tank
worked well with no problems at all for 25years or so
01-23-2015, 07:34 AM | #6 |
I think I found it...summit racing. Goodmark 4143-757-721 for 1972 C10 without evaporated emission system. will see?
01-23-2015, 08:33 AM | #7 |
Can You run a vent line back to the air filter? Mine is working fine with a fuel filter on the vent until I fill it up with gas then it blows a bit out the filter kinda like the venting system on a boat. I was thinking of running a vent line up to the intake on the air filter. This would leave a bit more volume for fuel to occupy before the pump shuts off at full and give the fumes from the tank to the engine for reburn. Thoughts?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Thread Tools | |
Display Modes | |
