Old 01-23-2015, 04:44 PM   #1
Jferrante
Jferrante's Avatar
Brake Booster Fitment Question for 64 c10
Quick question, will a 1971 Dual Master Cylinder and Brake Booster from a Chevy Nova fit on my C10 pickup? I see that the 71 booster setup from a pickup will work but didnt know if the nova's would be different.
Thanks for the help
Jferrante is offline   Reply With Quote
Old 01-24-2015, 02:20 AM   #2
Captainfab
60-66 Nut
Re: Brake Booster Fitment Question for 64 c10
You can make anything fit if you want to modify things and drill more holes in your firewall. It won't be a bolt on installation.
If you were to use my booster bracket, it bolts to the firewall using the factory bolt holes. This also ensures that the booster and master cylinder are solidly bolted to the pedal bracket and brake pedal under the dash as intended by GM engineers. There are many, many boosters that are compatible with my booster brackets. In addition to those listed in post #1 of the for sale thread, there is a more complete list in post #183 on page 8
Old 01-24-2015, 04:40 PM   #3
Jferrante
Jferrante's Avatar
ok I was planning on using your bracket. Are you suggesting it still wouldnt be a bolt on install with your bracket?
Old 01-24-2015, 06:03 PM   #4
LVPhotos
LVPhotos's Avatar
7" on Captainfab bracket
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-24-2015, 06:49 PM   #5
ray_mcavoy
The 1968 & newer Nova brake boosters have angled mounting brackets riveted to the rear shell. I don't think the angle of those brackets would work out very well for fitment into one of these trucks. And since they're riveted in place, removing them isn't an easy task.
ray_mcavoy is offline   Reply With Quote
Old 01-24-2015, 09:05 PM   #6
Jferrante
Jferrante's Avatar
great info thanks
Thread Tools
Display Modes
