Old 01-26-2015, 12:51 AM   #1
cruzinthecoast
cruzinthecoast's Avatar
installing a BBC 454
Thinking of swapping out a 350 for a 454 in my 48 pickup would like to hear from others who have done this swap. Anything I should know before I start. Clearance issues I should know about.
cruzinthecoast is offline   Reply With Quote
Old 01-26-2015, 04:32 AM   #2
crossfire84
crossfire84's Avatar
Re: installing a BBC 454
valve covers will hit the fire wall. i had to put a 3'' set back fire wall in.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 01-26-2015, 10:55 AM   #3
cruzinthecoast
Thanks never thought about the valve covers hitting. Was worried about the distributor hitting.
Old 01-26-2015, 04:05 PM   #4
pgf545
pgf545's Avatar
Take a look at my build thread, we did a big block in a 52. I think I would have had less trouble with it had we gone with a different accessory drive setup. We went with the March setup and it was really tight. But it will fit. Let me know if you any other questions.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 01-27-2015, 08:53 AM   #5
49bourbon
I put a BBC in my 49 suburban that has a 69 nova front clip. Moved motor back about 3 inches to get room in front for fan,etc and recessed firewall. I had to rework one of tubes on the headers on driver side to get around steering box. Just know you are putting the 10 pounds of "stuff" in a 5 pound box so plan accordingly. Also depending on BBC build it lots of torque so make sure you reinforce frame rails, crossmembers to prevent twisting of frame. Last thing to think about is brakes should be updated to help stop the beast. Good luck and post pics of the build.
49bourbon is offline   Reply With Quote
Old 01-27-2015, 10:24 PM   #6
YahamaR1
YahamaR1's Avatar
I installed a 454 BB in a 51"
It fits perfect, i also make a new firewall.
YahamaR1 is offline   Reply With Quote
Thread Tools
Display Modes
