Old 02-01-2015, 10:24 PM   #1
hdff
hdff's Avatar
Ac brackets bolt size
I am gathering parts to put the AC back in my truck. I bought some stock brackets that bolt onto the block and I need the bolts to attach them. I picked up a few popular sizes outta the bolt bin at work and none of them worked. The one I tried is on the front of the block by the water pump. Does anyone know what size and length is used. These are for a big block.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-02-2015, 12:48 PM   #2
hdff
hdff's Avatar
Re: Ac brackets bolt size
No one?
"Wanda"
Old 02-02-2015, 12:54 PM   #3
cooperhw
cooperhw's Avatar
You probably already know the thread diameter (more than likely 3/8" N.C.T.) by having removed the original bolt. To know how long a bolt you need I would put the bracket up against the hole and then put a pencil in the hole till it bottoms out. Mark the part of the pencil (or hold your fingernail on it) sticking out. You need a bolt 1/4" less in length than that.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 02-02-2015, 05:30 PM   #4
hdff
hdff's Avatar
No I do not know the diameter the PO did not have the brackets or bolts. The common size bolts I tried don't fit . I didn't look at the sizes of bolts when I snagged them out of the bolt bin, just got the sizes I thought were close
"Wanda"
Old 02-02-2015, 07:52 PM   #5
Fitz
Try a 3/8-16 national coarse bolt in the hole s you want to use. They will either be that size or 5/16-18 UNLESS your engine was made after 1980 then they are likely metric.
Fitz is offline   Reply With Quote
Old 02-10-2015, 11:19 PM   #6
hdff
hdff's Avatar
Well I found my problem the bolt size is 3/8 but the threads on the head are stripped. Is it possible to tap the hole to the next size. The things the PO did just amaze me. Any suggestions
"Wanda"
Old 02-11-2015, 12:21 AM   #7
Chucks72Longbed
Chucks72Longbed's Avatar
I would start with a 3/8" x 16 starter tap. The beginning threads on the tap are tapered enough to get into the good threads. Then you should be able to tap with a #2 or bottom tap to clean them up. If that doesn't work there is plenty of material around the bolt hole to jump to a 7/16" or 1/2". Carefull, don't go any deeper.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline   Reply With Quote
Thread Tools
Display Modes
