Old 02-03-2015, 10:31 PM   #1
vancelot69
vancelot69's Avatar
Driveshaft
Where can I buy a rear driveshaft? Looking on AutoZone, LMC and RockAuto I only see front driveshafts.
Or, is this fixable? The yoke is out of round and I can't press the old u-joint out. I bent my C-clamp trying.
The first one is the one that is out of round, the second one might be out of round too, but I wasn't sure, so I added it as a comparison point.
My toys:
1971 GMC Jimmy
2008 Hummer H3 Adventure
2003 HD Road King
vancelot69 is offline   Reply With Quote
Old 02-03-2015, 10:53 PM   #2
1rippen6
Re: Driveshaft
Try a WTB ad on the for sale forum
1rippen6 is offline   Reply With Quote
Old 02-04-2015, 03:24 PM   #3
landy
Re: Driveshaft
Try a shop that does differentials, axles, driveshafts, u-joints, etc. They can repair or make a new one.
landy is offline   Reply With Quote
Old 02-04-2015, 06:03 PM   #4
grillzy
Re: Driveshaft
rebuildable at a drive line shop
grillzy is offline   Reply With Quote
Old 02-04-2015, 07:39 PM   #5
Mike C
Mike C's Avatar
Re: Driveshaft
Most likely more than just that is whacked.
I had a new one made with a double cardan CV for the rear of my Jimmy. Good way to go if you have a lift. Mine was made by 6 States Distributors? I think Tom Woods used to work there maybe? He's who I would go to now probably.
I had a shaft made for the Nissan T5 in my 240z with 1310 U-joint on the diff end by a company named Wenco in California and was very happy with them as well. Would not hesitate to buy from them either.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-18-2015, 11:16 PM   #6
vancelot69
vancelot69's Avatar
Re: Driveshaft
Couple things:
Since I took the rear shaft out, so my truck wouldn't roll away, I engaged the front hubs and put the transfer case in 4-Hi. Since then, I have driven it a handful of times and I am VERY impressed with how it handles in "front" wheel drive mode. It's as smooth as glass, even when I have the wheel cranked going around a corner, it's not all herky-jerky like I've felt in some 4x4 trucks I've owned. Of course, after thinking about it for a minute, that could be because I don't have the rear wheels pushing against where the front wheels are trying to pull it to...
Second, I took it to Ft. Worth Gear & Axle off E. Long Ave. They said they can't just re-round the yoke hole, so the whole slip joint had to be replaced. For $65, and $15 per u-joint to install the ones I had. I was more than happy to have it done for that price. While I was there, I asked about converting it to a double cardan or CV or whatever, and he said it would probably be close to $300 to do that. So, since a new FRONT drive shaft is about $300, I figure that's probably a pretty good price to get the rear one done. But I can't afford that right now, so just getting the new slip joint is fine for now. Plus, the guy at the shop said that if it wasn't wobbling (until the u-joint broke), then it should be fine as-is and I shouldn't need a CV on the rear.
My toys:
1971 GMC Jimmy
2003 HD Road King
Old 03-21-2015, 01:53 PM   #7
vancelot69
vancelot69's Avatar
Re: Driveshaft
New slip joint / yoke. They also painted the old tube.
My toys:
1971 GMC Jimmy
2003 HD Road King
Old 03-22-2015, 09:05 AM   #8
Chulisohombre
Chulisohombre's Avatar
Re: Driveshaft
That's a good price. Looks like they did a good job. Main thing is that the checked the ballence on the shaft. That way at speed you don't get vibration. But if it didn't break or have a problem before, you should be good.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-22-2015, 12:08 PM   #9
vancelot69
vancelot69's Avatar
Re: Driveshaft
Yeah, they might have balanced it, but I didn't see any weights on it.
When I was going to put it back in, I got out the Chilton or Haynes that I have and noticed that it said to mark the relation of the driveshaft to yoke during removal, which I didn't do, on either end. On the slip joint side, no big deal since that part is new. I took it out for a drive yesterday evening after I got it put on, only got up to about 40-45, but it felt fine!
My toys:
1971 GMC Jimmy
2003 HD Road King
Old 03-22-2015, 12:12 PM   #10
Chulisohombre
Re: Driveshaft
With new joints you should be fine.
Thread Tools
Display Modes
