Old 02-06-2015, 11:23 AM   #1
tailgate hinge bushings ? where do you find quality...
...Replacements. Just bought a cheesey kit from NAPA for 15 bucks and the pieces will not fit, its junk. My tail gate rattles around big time due to the lower hinge bushings either missing or worn out.
Where are y'all finding these?
Old 02-06-2015, 11:38 AM   #2
tucsonjwt
Re: tailgate hinge bushings ? where do you find quality...
Junkyards have lots of them. You can inspect them prior to purchase to make sure that they are in good shape. Ebay is another choice. Most likely you got Chinese aftermarket parts from NAPA, and that will be true for all new parts. Also, be aware that the design did change and not all 73-87s are interchangeable.
tucsonjwt is offline   Reply With Quote
Old 02-06-2015, 12:22 PM   #3
rich weyand
rich weyand's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=645413
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-06-2015, 02:18 PM   #4
ddr11
ddr11's Avatar
I have urethane bushings in mine (like skate board wheels)...Note
; mine is a step side
ddr11 is offline   Reply With Quote
Old 02-06-2015, 02:24 PM   #5
Mine is an 88 with the ob-long piece on the truck and some kind of bushing to accept it in the tailgate (on the slotted side where you lift up the gate to remove it).... Hope that makes sense
Old 03-13-2015, 07:25 PM   #6
1966chevy
1966chevy's Avatar
1954-1987 Chevy GMC Truck Stepside Tailgate Hinge Trunnion "Patent pending"
Ultimate Hinge Trunnion (4 Piece Set) made of Stainless Steel/Delrin replacement part!
Made in USA!
These are very quiet while opening and closing the tailgate. See the pictures
Website is: tdtrunniondesign.com
Available on Ebay right NOW!
http://www.ebay.com/itm/171718930810...84.m1555.l2649
These are hinge trunnion replacement parts to upgrade your Chevy Stepside Truck.
The Trunnions are manufactured from Delrin and 303 stainless steel.
I have a picture listed of the replacement trunnions that are zinc plated which will still rust on your truck. I also show the original trunnion that was removed and has rusted and made that awful sound while opening and closing the tailgate. You can reuse your bolts and lock washers, but would recommend you use stainless steel bolt and lock washer. Be sure to use an antilock lube when reinstalling your Trunnions, prevent bolt lock! Just remove the bolt with lock washer, replace with these stainless steel hinge trunnions and bolt back on your truck just in reverse of how you removed it from the truck.
No more greasing the trunnion, No more rusting, No more noise with a huge improvement, smooth opening and closing of your tailgate! You'll love it!
Free shipping USPS in 50 states.
Material used:
Delrin is a Acetal AF blend, supplied as a 2:1 blend of Acetal AF-100 and Acetal 150 resins, has excellent sliding/friction properties. Bearings made of Acetal AF blend can operate at higher speeds while exhibiting reduced wear. These bearings are also essentially free of slip-stick behavior because the static and dynamic coefficient of friction are closer than with most plastics. Acetal AF blend retains 90% of the strength that is inherent in unmodified Acetal.
303 Stainless Steel is very similar in properties to that of 304 Stainless Steel, However 303 has an addition of sulfur for better machining characteristics. 303 Stainless Steel is Corrosion resistant to temperatures of 1500 Degrees or more. It is used in screw machines, food processing equipment, marine applications, and some aerospace application.
1966chevy is offline   Reply With Quote
Old 03-13-2015, 08:27 PM   #7
rich weyand
Stainless steel is more cathodic than carbon steel, cad-plate, and other steels. Which means if you bolt stainless steel to regular steel, the stainless steel won't rust, but it will accelerate the rusting of the steel it is electrically connected to.
Rich Weyand
1978 K10 RCSB DD.
Old 03-13-2015, 10:24 PM   #8
1966chevy
1966chevy's Avatar
Preventing galvanic corrosion-
There are several ways of reducing and preventing this form of corrosion.
1. Electrically insulate the two metals from each other. If they are not in electrical contact, no galvanic couple will occur. This can be achieved by using non-conductive materials between metals of different electropotential.
2. Ensure there is no contact with an electrolyte. This can be done by using water-repellent compounds such as greases, or by coating the metals with an impermeable protective layer, such as a suitable paint, varnish, or plastic.
Someone that is purchased this item has the highest regard for their vehicle, that wants to improve it, last longer, work better and hopefully the vehicle is painted and cared for properly. As long as there is paint in between they both should last a very long time. Thanks
66 Chevy Truck LS1
67 Camaro Convertible
Old 03-13-2015, 10:31 PM   #9
rich weyand
Yes, and you also have to make sure the fasteners do not create the electrical connection.
This is why I chose powder-coated steel rather than stainless steel side bars for my vehicle. I didn't trust that I could guarantee the electrical isolation of the stainless steel ones, particularly where they would get wet so often from road spray. For interior items it is much easier.
Rich Weyand
1978 K10 RCSB DD.
Old 03-14-2015, 04:59 PM   #10
BamaDave
http://www.mar-k.com/
BamaDave is offline   Reply With Quote
Old 03-14-2015, 05:25 PM   #11
1966chevy
1966chevy's Avatar
Originally Posted by BamaDave View Post
Total different! Different material and designed better more higher quality made.
Old 03-14-2015, 06:54 PM   #12
BamaDave
http://www.mar-k.com/Catalog/m/mCatalog.aspx?CID=83#83
Which ones are better?
Old 03-14-2015, 09:01 PM   #13
rich weyand
The ones he's selling on ebay, presumably.
Rich Weyand
1978 K10 RCSB DD.
Old 03-15-2015, 04:43 AM   #14
cerial
cerial's Avatar
Want a cheap fix that will outlast the truck?
Get a bit of 1.75" 1/8 wall tube. Weld that in place of your "fixed" side. Weld a piece of 1.5" pipe to the tailgate on the fixed side.
Once everything is welded up slip a piece of radiator hose with a 1.5" id over the 1.5" tube using grease.
On the other side you cut a slot in the 1.75 tube so you can slip the pipe in.
Slide the one side in then drop in the other and attach your chains/straps.
The rubber will be tough to get in at first. But after a while it will work down and be great. If the tailgate rattles in another 8 or so years just replace the hose.
It is one of those fixes that no one will ever notice, can be done for $20, and around 2 hours of time.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 03-17-2016, 07:16 PM   #15
1966chevy
1966chevy's Avatar
1967-1972 and 1958-1966 Truck Fleetside Tailgate, Ultimate hinge Trunnion (6 Piece Set) made of Stainless Steel and Delrin. Now offering the complete SET!
These are replacement hinge trunnion parts to upgrade your chevy fleetside truck.
These are perfect for the truck restorer!
These are Very quite while opening and closing the tailgate.
See my attached link if your interested in purchasing"
http://www.ebay.com/itm/171709176937...#ht_559wt_1094
I also offer a cheaper version, Made of all Stainless steel on this listing:
http://www.ebay.com/itm/171709178087...#ht_413wt_1094 SOLD OUT
http://www.ebay.com/itm/171743832627...84.m1555.l2649 SOLD OUT
I also in the works on building 67-72 trunnion hinges.
http://www.ebay.com/itm/171709178881...#ht_430wt_1094
Website is: http://tdtrunniondesign.com
My project, http://67-72chevytrucks.com/vboard/s...d.php?t=552896
66 chevy truck Fleetside LS1
67 Camaro Convertible 327
Ebay Product reviews
Fast shipping and worked perfect.
67 68 69 70 71 72 Chevy/GMC Truck Fleetside tailgate SS Trunnions Hinge SET
thanks for the trunnion hinges, fast shipping, great price, will buy from again!
58 59 60 61 62 63 64 65 66 Chevy/GMC Truck Fleetside tailgate Trunnion Hinge SET
great part, really helped with the rattling tailgate problem
I have been hyping you up in instagram & the 47-72 truck forum. Great product!
Quick and easy...product is awesome, Thanks
Item as described, fast shipping...Thanks!
Great seller! Super fast shipping! Amazing quality product! Thank you!
Quality Product MADE IN THE USA well packed FAST SHIPPING thanks again
Quick and easy service with high quality parts.
1954-1987 Chevrolet GMC Truck Stepside Tailgate Trunnion Hinge SET
awesome
Nice Looking product, fast shipping. Would buy again!
Nice product
Old 11-17-2016, 07:55 PM   #16
1966chevy
1966chevy's Avatar
1967-1972 and 1958-1966 Chevy Truck Fleetside Tailgate, Ultimate hinge Trunnion (6 Piece Set) made of Stainless Steel and Delrin.
1953-1987 Chevy Truck Stepside Tailgate, Ultimate Trunnion (4 Piece Set) made of Stainless Steel and Delrin. Now offering the complete SET!
These are replacement hinge trunnion parts to upgrade your chevy truck.
These are perfect for the truck restorer! Website is: http://tdtrunniondesign.com
They were mentions in the following:
Hotrod Magazine
Classic Truck Magazine
As the "Silent gate"
C10 Source journal
Stainless Steel C10 Trunnions
Website is: http://c10source.com/c10-journal/page/2/
#chevytrucks #trunnions #c10source #hotrodmagazine #classictruckmagazine
Thread Tools
Display Modes
