02-07-2015, 06:41 PM | #1 |
New to timing?
Have a 1972 GMC 350, just purchased a Petronix igniter, flame thrower coil, new cap, rotor, wires, and spark plugs. Plan to install tomorrow, set plugs at .045, and recheck timing.
Here is the question: when checking what my timing currently is (12) I was going to move down to 8-10 and see how she reacts. The manual states "adjust timing by loosening distributor clamp and rotating the distributor body" is this the clamp holding the distributor? I loosened this to the point of removal and still nothing moved. What is a stupid guy missing here?
1972 GMC 2500 2007 Chevrolet Silverado 1500 |
02-07-2015, 06:47 PM | #2 |
Re: New to timing?
Loosen the bolt/clamp at the base of the distributor where it meets with the intake. Then rotate the distributor by hand to adjust timing.
It does not move on its own. |
02-07-2015, 06:57 PM | #3 |
Re: New to timing?
I think ya got the right bolt. you don,t have to loosen it very much.
remember to warm it up, keep the idle down below 800 or the dist weights will start to advance the timing and unhook and plug vacuum line to dist hose at the manifold/carb. |
02-07-2015, 09:24 PM | #4 |
Re: New to timing?
That is the one I loosened? Will be taking her out tomorrow and pass on how it goes. Wish me luck.
02-07-2015, 11:43 PM | #5 |
Re: New to timing?
Kool every time I pull my dist. it never wants to go back in like it was. if I make sure I'm on TBC and put a mark on the engine inline with the rotor when its pointen at number 1 I can eventually get back close. the darn oil pump rod moves alittle when I lift the dist and it wants to set down one tooth off when I put it back in. I just put a accel conversion in my trk. runs good.
02-08-2015, 02:06 AM | #6 | |
Re: New to timing?
02-08-2015, 08:33 AM | #7 | |
Re: New to timing?
I bet if you can't turn your distributor, your hold-down clamp is way too tight- the diameter of the distributor base might be wider than the inside diameter of the hold-down clamp. The base on my cast flamethrower was even bigger than the one on the MSD I removed and I had to dremel some clearance to make it fit properly.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
02-08-2015, 09:24 AM | #8 |
Re: New to timing?
How long has the distributor been in there?
Mine was almost completely stock when I picked it up. I had to use a BFH to break it loose and 2 pry bars to lift it out |
02-08-2015, 02:41 PM | #9 | |
Re: New to timing?
02-08-2015, 07:11 PM | #10 | |
Re: New to timing?
no. 1 to TDC Position rotor to point to front of engine turn rotor appx. 1/8 turn ccw towards left bank and push dist. down to camshaft While pressing firmly down on dist. housing kick or turn engine over until oil pump shaft is engaged make sure rotor is pointed at no. 1 on dist and crank is at TDC snug down the hold down clamp and it should be close enough to get started. Looks like stock for your truck is around 6 but with this gas we got now seems better around 10 Does that sound better guys? |
02-08-2015, 07:26 PM | #11 |
Re: New to timing?
Well day went well thanks to the advice of everyone. I think everything has been there from the factory. It took some time to free the distributor (that is why she wouldn't turn), putting on the points eliminator required me to remove the gear and add a spacer, screwdriver trick worked great getting everything back lined up, she fired right up, timing was at 8 and I moved her back to 12 where she was stock. Runs great! 8 is in the manual but is 12 okay?
I still have every spark plug wire clamp, plug heat shield, etc from factory in great condition. Getting everything back routed correctly was time consuming but worth it. I also replaced the vacuum advance as the arm was bent. Thanks for a great day in the garage.
02-08-2015, 07:49 PM | #12 | |
Re: New to timing?
Try 15. Or better yet, if you have a degreed balancer or a nice timing light with a dial, set the total advance at 36' and see where the base timing falls. With the vacuum pod dis-connected, rev it till it quits advancing and set the 36'. Record where it stops advancing with a tach if you can. If it cranks the same, does not ping and you don't exceed 36' total timing, it's all good; better power, mileage, and cold drivability. |
Thread Tools | |
Display Modes | |
