Old 02-09-2015, 01:27 AM   #1
SickAss 62 C10
SickAss 62 C10's Avatar
looking for an IFS
okay guys i'm jumping in with both feet so i'm gonna start with a IFS . dose anyone have any ideas of where i can get a low cost, high quality independent front suspension or a place near Fresno Ca. that can build me one
SickAss 62 C10 is offline   Reply With Quote
Old 02-09-2015, 02:05 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: looking for an IFS
Low cost, high quality, and custom built will never exist in the same sentence when it comes to hotrod parts. Companies like No Limit are forum vendors here and have IFS kits, but they aren't cheap.
Realistically, the lowest-cost and already engineered solution would be to get a whole front crossmember off a 73-87, and bolt the thing in place. You automatically get disc, the ablility to run power steering, and the coil spring setup. Its also by far the cheapest. Heck, just buy a donor truck, swap the crossmember and steering stuff all at once, and do drop spindles while you're in there, converting to 5lug. Take the rear axle off the truck and use it for the rear.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-09-2015, 09:34 AM   #3
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
? I don't understand. you already have an independent front suspension. if you want to upgrade relatively inexpensively, do the swap that BR3W suggested and add '71-'72 models to the list of donors (although the later models are preferred)
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-09-2015, 01:30 PM   #4
LVPhotos
LVPhotos's Avatar
There's nothing wrong with torsion bars. They sell all parts to rebuild and drop spindles to swap in disks.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Thread Tools
Display Modes
