Old 02-09-2015, 04:09 PM   #1
1968aj
headlight switch
I put in a new headlight switch. the handle will not stay in. it will not click back in to place.i messed with it for an hour but it just pulls out of dash and will not catch into the switch. I know about the button that releases it. what am I doing wrong?? maybe I need to get out my hammer.
1968aj is offline   Reply With Quote
Old 02-09-2015, 04:49 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: headlight switch
All I can think is maybe the release button is sticking and not catching...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-09-2015, 05:28 PM   #3
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: headlight switch
Are you using the stem for the new switch are the old stem? If using the old stem with new switch the catch on the stem maybe off set from the new switch.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-09-2015, 06:26 PM   #4
leftybass209
leftybass209's Avatar
+1
+1
Could be either problem depending on what you did. Also the brand of headlight switch will dictate how well it works.
leftybass209 is offline   Reply With Quote
Old 02-09-2015, 07:25 PM   #5
Steve Cole
Mine did the same thing. Sometimes they just stick and will not catch. I almost gave up on mine then it finally caught. Keep trying!
Steve Cole is offline   Reply With Quote
Old 02-09-2015, 07:44 PM   #6
michael bustamante
michael bustamante's Avatar
a 3 pound sledge outta do it.
1967custom
michael bustamante is offline   Reply With Quote
Old 02-09-2015, 07:56 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
- Mike -
RIP El Jay
Old 02-09-2015, 08:51 PM   #8
1968aj
well, I just wasted another hour on this switch with no luck.the new stem and the old one work in the old switch. neither will catch in new switch. ihave had this new one working because I removed it before. all I can do is get another one and see what happens. if that does not work im getting out the hammer!!
Old 02-09-2015, 08:56 PM   #9
Andy4639
Old member
Andy4639's Avatar
Question Re: headlight switch
Take the nut loose on the switch and see if it catches. If not take it completely out of the truck and try it. When you pull the switch stem out are the lights coming on?
Old 02-09-2015, 08:58 PM   #10
1968aj
now that this switch has kicked my*** how do you remove the gearshift selector arm on automatic column? any tips?
Old 02-09-2015, 09:20 PM   #11
slikside
slikside's Avatar
Take a small punch, and with a hammer drive the pin out. It will just pull right out of the column then.
This one is a synch compared to any headlight switch issue!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 02-09-2015, 11:27 PM   #12
1968aj
THANKS. now I can use my hammer.
Old 02-10-2015, 09:30 AM   #13
blkseetin
Question regarding headlight switch on my 70 c10... When I pull the headlight knob, the headlights come on fine, but occasionally the dash lights do not come on. When this happens, I can fiddle with the knob by turning it on and off a few times, and twisting it back and forth and it comes on after a minute or so of this. My question is, is this a problem with a loose wire, or is this a bad switch that I just need to replace? Anyone else had this problem?
blkseetin is offline   Reply With Quote
Old 02-10-2015, 10:10 AM   #14
steelhorse
steelhorse's Avatar
Depending on where you got the switch it could be just a bad part. In this day where everything is made in China I spend a lot of time replacing so called "quality" new parts.
steelhorse is offline   Reply With Quote
Old 02-10-2015, 10:19 AM   #15
blkseetin
it's most likely the original. This was my grandfathers truck, and he passed away last year. The truck was given to me, and it only has 49k miles on it. as far as I know, it's all original parts at this moment, but I'm finding a bunch of stuff that needs to be replaced. I'm considering rewiring the entire truck though. My grandfather seemed to enjoy cutting wires and adding additional accessories. Thanks Paw Paw!!!
Old 02-10-2015, 10:23 AM   #16
1968aj
I bought rear brake wheel cylinders and one would not fit. then I bought new brake drums and one would not fit. they were packaged wrong or just machined wrong. took twice as long to do brakes with all the trips to auto parts
Old 02-10-2015, 08:45 PM   #17
1968aj
finally.headlight switch is in!!took switch out of dash and knob popped right in. put switch back in dash and it went right in . NOW my taillights quit working. it never ends.
Old 02-10-2015, 08:47 PM   #18
EARNHARDT#3
EARNHARDT#3's Avatar
You could be chasing a turn signal switch issue.
EARNHARDT#3 is offline   Reply With Quote
Old 02-10-2015, 09:00 PM   #19
1968aj
taillights were working before I started this. previous owner put a painless wiring harness in. the old harness is still hanging under dash looks like a bomb went off under dash. I have a new aaw complete harness. trying to build up the courage to start complete rewire
Old 02-10-2015, 11:38 PM   #20
frankslagoon
I think that's pretty common with old switchs. there is a reastat that controls the dashlite brightness. on the switch. like the old school heater speed controls. just a long spring between the power circuit to the dashlites. there is a contact that moves across it when ya turn the knob. they get wore out or rusty and don't make good contact.
frankslagoon is offline   Reply With Quote
Thread Tools
Display Modes
