Old 02-11-2015, 09:40 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Help with Seat Belt Bolt
I am trying to get the pictured bolt out. I used a 13/16 swivel socket and a hand ratchet on it and it loosened a bit. Now it won't budge in either direction even with an impact drill. I know it's been there 43 years but.. Anyone got any ideas
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-11-2015, 09:57 AM   #2
carsonmx114
Re: Help with Seat Belt Bolt
move the carpet out of the way then heat the nut from underneath with a map gas torch. Try to heat the nut quickly and avoid heating the bolt as much as possible. The idea is to expand the nut before bolt heats and expands with it. This will give the threads a little more clearance. Also heat will draw in penetrating lubricant if you have some to spray on it while it's hot.
carsonmx114 is offline   Reply With Quote
Old 02-11-2015, 10:23 AM   #3
Already Gone
Thanks and I'm sure that will work. I am working without a hoist so I don't want to play with a torch lying oy back under the truck.
Old 02-11-2015, 10:29 AM   #4
Mike C
Mike C's Avatar
Screw it back in and put lots of penetrant on the protruded threads. Then screw it out. Then screw it in and re-apply. Repeat until it comes out.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-11-2015, 10:46 AM   #5
Already Gone
It won't screw back down, even with an impact.
Old 02-11-2015, 11:10 AM   #6
carsonmx114
We use the handheld butane type torch for most of our stuff around the shop. It's much easier to manage. It won't get the stuff red hot but it usually gets it hot enough to break loose. I have a oxygen acetylene setup but I rarely need it. You may even be able to heat it from the top as the heat will transfer to the nut if you heat the metal around the bracket. It will cook your paint around the mounting point though.
Old 02-11-2015, 11:12 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
If you can get a small hammer in there spray around the threads with the penetrating oil then rap it on top quite a few times with the hammer. If you can't get a hammer in there your only option is the heat or a 25" breaker bar...... If you don't heat it you may twist off the weld nut under the floor. I have also heated the bolt from the top but you have to let it cool completely before trying to remove it if you do that.
LockDoc
Leon
Old 02-11-2015, 11:21 AM   #8
brown7373
brown7373's Avatar
Actually, I don't think it has been in there 43 years, as I don't think it is an original seat belt bolt. A seat belt bolt looks like some variation (length, shoulder) of the one on the left. Might it be the wrong thread and forced in?
brown7373 is offline   Reply With Quote
Old 02-11-2015, 11:45 AM   #9
Keith Seymore
Keith Seymore's Avatar
I suspect you might be able to put more torque to it with a 1/2" or 3/4" breaker bar and cheater pipe. Then do the back in/back out technique as suggested above.
I can usually break things loose (...or just break things) with the big wrench more than I can with my impact. Given a long enough lever you can move the world (Archimeides would have been a pretty good mechanic).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-11-2015, 12:47 PM   #10
Mock1
Then more than likely, its stripped.
Probably from not being the correct thread.
Big breaker bar, cheater pipe and hope it dont break the bolt.
I just gotta get out here and do it, why?
Cause nobody will do it for me...
Mock1 is offline   Reply With Quote
Old 02-12-2015, 10:22 AM   #11
Already Gone
Thanks everyone for your suggestions. I took the truck to my friends body shop and they used a air impact drive to get them out, and the air diver worked pretty hard to remove them. Intriguing someone said they might not be the original bolts. I will post pics of the bolts in this thread later today and if someone could post pics of an original bolt for comparison, I'll appreciate it.
Old 02-12-2015, 11:11 AM   #12
Mock1
Just took mine out of my 67 last night, will post them tonight as well. Should be the same.
Old 02-12-2015, 12:42 PM   #13
LockDoc
LockDoc's Avatar
No picture on the computer but I have found two different styles, one with a shoulder and larger head and one without. The ones without the shoulder look like a regular bolt. I believe they are grade 8.
LockDoc
Leon
Old 02-12-2015, 05:45 PM   #14
Mock1
What year? Dont know if these different for what years but...
Here's a bolt from a 67.
Bolts on the 69 are the same.
Old 02-12-2015, 10:51 PM   #15
Already Gone
Here are the pics of the ones form my truck. I have 2 like this. Does anyone know if these are correct for a 72 C10.
Old 02-12-2015, 11:08 PM   #16
joeydurango
joeydurango's Avatar
I do not know if those are correct for sure, but both sides of my '72 K10 are much more like what you just pulled out and not at all like what was pictured from the '67 above.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 02-12-2015, 11:15 PM   #17
ironman3452
ironman3452's Avatar
work it back and forth, oil, and a cheater bar on a 1/2 inch wratchet
ironman3452 is offline   Reply With Quote
Old 02-12-2015, 11:23 PM   #18
leddzepp
Moderator
leddzepp's Avatar
That's a 7/16-20 (fine thread) bolt, used in 67 only. All other years take a 1/2-13 (coarse thread) bolt.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-12-2015, 11:39 PM   #19
LockDoc
LockDoc's Avatar
If those were both in the retractors I think they are correct.
LockDoc
Leon
Old 02-13-2015, 08:57 AM   #20
Mike C
Mike C's Avatar
Not sure if that's a grad head marking or if it is a manufacturers mark. If it's some odd grade mark, that may even be a metric fastener. Definitely not the correct bolt.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-13-2015, 09:41 AM   #21
bluek5
bluek5's Avatar
Yes that is the correct bolt.
Paul
bluek5 is offline   Reply With Quote
Old 02-13-2015, 09:46 AM   #22
Already Gone
Paul
I'm getting conflicting info on these bolts. The post above yours in the thread says my pictured bolts are not correct. Are the bolts in your truck the same as mine?
Old 02-13-2015, 10:11 AM   #23
bluek5
bluek5's Avatar
I have removed dozens of the bolts for the retractors. I will take a couple of pictures of one if you would like. The retractor bolts are not shouldered because they do not swivel. The two inside belt bolts are shouldered. Your bolt is correct right down to the putty on the bolt from the original installation. Hope this helps.
Paul
Old 02-13-2015, 10:36 AM   #24
Already Gone
Paul
Thank you Paul. Yes there was yellow putty on the bottom of the the bracket the bolts went through as well. I will reuse these ( after a turn with the wire wheel to clean up the threads) when I reinstall my seat belts.
Old 02-13-2015, 11:14 AM   #25
LockDoc
LockDoc's Avatar
..with Paul.... I have removed a lot of them too.
LockDoc
Leon
Thread Tools
Display Modes
