02-11-2015, 03:36 PM | #1 |
Steering column 101
I'm in the market for a column for my 1977 C10 2wd. I measure it right at 35" long. I'm not finding one in the aftermarket that length. What is the correct way to measure a steering column? I'm measuring it from the end that bolts to the steering shaft to the area right below where the wheel mounts.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
02-11-2015, 11:32 PM | #2 |
Re: Steering column 101
Is there a reason you want an aftermarket column? Factory ones are readily available and in most cases a lot better quality that most aftermarket with the exception of Ididit and Flaming river. Is it a certain look you want?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
02-11-2015, 11:58 PM | #3 |
I don't necessarily want an aftermarket one. A factory style will so me just fine. My truck was a 3 on the tree and now I have a floor shifter so I want to do away with the manual column.
Thread Tools | |
Display Modes | |
