02-12-2015, 12:59 AM | #1 |
Sanden SD 7 mount option
I was struggling with where to mount my A/C compressor. I'm going to use a vintage air system, so I will need to use a Sanden compressor. There are all kinds of mounts out there for this application, but I really don't like the accessories to be high and wide. I prefer everything to be tucked in nice and tight. Spending 2k+ on a drive system was out of the question as well.
Here is what I came up with. I got the water pump for a 2010-13 Camaro. These use the truck spacing, so it lines up with the other accessories with no shims. I was thinking I might be able to utilize the tensioner mount as the base for the compressor mount. I confirmed that if I used 3/16 aluminum plate to make the brackets, the compressor would line up perfectly using the stock tensioner mount. The only mod I had to do to the water pump was to "machine" the back of the tensioner mount so that my bracket plates would have the correct spacing. I used a router (yes, one for wood) to mill the back of the mount. As long as you lubricate between passes and don't get aggressive, the router works great. I used the aluminum plate to square up with the back of the pump, and as a guide for the router. Everything lines up perfectly, but I was not able to use this first style of mount. the compressor was actually too low, and I didn't have room to add a tensioner. See the next post for the updated pix. |
02-12-2015, 01:17 AM | #2 |
Re: Sanden SD 7 mount option
In this iteration, I raised the compressor up a few inches and rotated it level. I also moved it in towards the center line about 3/4".
I had a heck of a time finding a tensioner that would work. I'm sure the guys at O'riley's and Napa were pretty tired of me buying and returning a bunch of tensioners plus all the ones I had them pull out only to find they went the wrong way or were just too far off. I also wanted to add some thicker material for the tensioner to mount on which ended up being 1/2" aluminum. This gave me the proper spacing with the tensioner, and I felt it was strong enough. I also positioned the tensioner so that the mounting bolt would extend through all the brackets and into the head for added support. The tensioner ended up being off of a diesel pickup, but I like the look and it is pretty beefy. I also made my own power steering bracket (more of a block really) and went with an eBay alternator mount. This leaves a hole where the original AC compressor was mounted, which may make way for a single turbo later on. I've got about $700 into my accessory drive and that includes a new compressor, alternator, water pump, tensioner, belt and power steering pump. |
02-12-2015, 09:08 AM | #3 |
brother do us a favor, looks like a work of art in progress, but put some paint or powder coat on that crank pulley, sticks out like a third eye
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-12-2015, 09:13 AM | #4 |
I know on the crank pulley. It's getting replaced after mock up is done. I should throw some paint on it out of self respect though.
02-12-2015, 09:18 AM | #5 |
Lol
02-12-2015, 10:05 AM | #6 |
can you make me one of these ac mounts? im doing a single turbo too
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 02-12-2015 at 10:06 AM. Reason: mispell |
02-12-2015, 05:32 PM | #7 |
This is a very nice set-up. The '71 Cheyenne is going to get LSx'd, so this sort of info is pertinent. No hurry, though, the '69 GMC is up next.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
Thread Tools | |
Display Modes | |
