02-12-2015, 10:24 AM | #1 |
72 c15 motor mount confusion
Hi guys, was curious if you guys could post some images of your 350 motor mount I'm just confused on the motor mount the parts store gave me compared to what I think goes on there.
02-12-2015, 01:01 PM | #2 |
Re: 72 c15 motor mount confusion
Should be a clam shell style mount, similar to the later models
02-12-2015, 02:33 PM | #3 |
[QUOTE=kwmech;7045316]Should be a clam shell style mount, similar to the later models
I attached some pictures |
02-12-2015, 03:30 PM | #4 |
the one you are holding is the earlier style. The clamshell is the newer one.
02-12-2015, 03:31 PM | #5 |
yup thats 67-71
1967custom |
02-12-2015, 05:21 PM | #6 |
Should this work on my 72? Went back to the parts store and said this is what fits the 72.
02-12-2015, 05:26 PM | #7 |
NO. that's for the earlier models. You need the clamshell style.
From what I have found you can ask for 73+ motor mounts but the word on the street is they are slightly different. I had to beat, pry and plead to get the motor to drop back in. heres a thread that will make it clear as mud http://67-72chevytrucks.com/vboard/s...d.php?t=634402 take a pic of your current mount and we can tell you which you have. |
02-12-2015, 06:18 PM | #8 |
Have A Nice Day!
In 1972 the small blocks still used a mount like the one pictured in #3 post. In 1972 the big blocks were mounted using a clam shell style mount like the one pictured in the above link.
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ |
02-12-2015, 08:34 PM | #9 |
02-12-2015, 09:21 PM | #10 | ||
"I ain't nobody, dork."
My 1972 GMC C1500 has the exact same ones as in post #3. SBC 350 from the factory.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-13-2015, 09:57 AM | #11 |
I think you guys are confusing the issue. The OP said an SBC 350,, not a BBC '72 only clam. The mount pictured bolts to the block with three bolts then it sets on the stands and one bolt retains the mount to the stands from the underside. I can take a pic this afternoon if needed. What frame stands/perches are you working with jomatt?
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Thread Tools | |
Display Modes | |
