Old 02-12-2015, 07:53 PM   #1
PartyPooper
Rear Axle Seal
Hello, I've searched the site but I'm still looking for a little advice because I'm a bit confused.
I'm a proud but sometimes frustrated owner of a 70 GMC Grand Sierra 3/4 Ton truck.
It looks like I need to replace my rear axle seal. Apparently I'm looking for a lock screw so I can remove the pinion shaft from my differential. I can't seem to locate that screw. Also, because it appears my rear axle is different from those I've seen I thought there might be a different procedure for removal.
Any help is appreciated, the gear is labeled Dana 32503 A808 46-13 (if someone could also help me identify the rear end type). Thanks - Earl
PartyPooper is offline   Reply With Quote
Old 02-12-2015, 09:28 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rear Axle Seal
Remove the 8 bolts on the end of the axle at the hub and the axle should slide right out. Then you have to remove the hub off of the axle spindle to get to the seal.
The lock bolt you've been searching for to release the pin is for a C-clip style axle like a 12-bolt.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-12-2015, 11:12 PM   #3
Bigdav160
Bigdav160's Avatar
Re: Rear Axle Seal
Dana 60 with a powerloc
The axle seal is in the hub. Once you remove the axle it helps to have the correct socket to remove the hub
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-13-2015, 12:27 AM   #4
PartyPooper
Re: Rear Axle Seal
Thank you both - I pulled out the axle after reading Gary's response and tried getting it off with a set of channel locks but if I measured right I'll need to grab a 2 3/8" socket. BigDav160 thanks for the ID on the diff - now I can grab the parts tomorrow and maybe get this done this weekend.
Old 02-13-2015, 08:52 AM   #5
Mike C
Mike C's Avatar
Re: Rear Axle Seal
You lucky dog. The PowerLock is probably the best limited slip differential ever made. Completely rebuildable and adjustable. Make sure you add some limited slip additive when you refill the differential housing.
As mentioned above, you have a Dana 60. Yours has 3.54 gears (46/13=3.538)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-13-2015, 02:04 PM   #6
GASoline71
GASoline71's Avatar
Re: Rear Axle Seal
Sweet. I have accumulated a whole bunch of very large sockets and specialty sockets from different diffs over the years. D60's, front D44's, 14-bolt FF's 14-bolt SF's, etc., etc... Some have only been used once by me but borrowed by a lot of buddies over the decades.
Gary
Thread Tools
Display Modes
