Old 02-17-2015, 08:05 PM   #1
kevinr1970
TBI fuel pump.. test?
In talking to guy about a '90 Suburban, he said the fuel pump was bad, but the truck runs real good.
I asked why he thought the pump was bad and he said that it quit running so he had a friend turn the truck over while he banged on the tank with his hand and it started right up?
He said if I wanted to see/hear it run he would bang on the tank while I started it.
Why would hitting the tank affect the pump working or not, outside of maybe a short in the wiring?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-17-2015, 08:20 PM   #2
pontgta
pontgta's Avatar
Re: TBI fuel pump.. test?
Loose electrical connection or could possibly be the pump is stuck. You can hear the pump while turn the key foward momentarly. If you can not hear the pump then ther is an issue.
pontgta is offline   Reply With Quote
Old 02-17-2015, 08:41 PM   #3
kevinr1970
So what if you can't here it, until you hit the tank?
I am cool with it needing a pump, I might even have one in my '91 parts Suburban.
Just curious why hitting the tank would do anything!
2000 Tahoe Limited
Old 02-17-2015, 11:17 PM   #4
pontgta
pontgta's Avatar
If you can't hear, i would say more than likely be pump. But I would check it just in case. sounds like an easy fix because if it you can crank the engine and keep it running with that same pump.
Old 02-18-2015, 09:53 AM   #5
SCOTI
SCOTI's Avatar
Banging on the tank sometimes frees the pump up & they start working (just like whacking a old stubborn sbc/bbc starter).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-18-2015, 11:08 AM   #6
Bigstevex4
Bigstevex4's Avatar
Yes that trick does work sometime have ever bhad and elec house fan you had to kick start same thing.
Bigstevex4 is offline   Reply With Quote
Old 02-18-2015, 04:50 PM   #7
kevinr1970
Went and looked at it last night and the battery was toast and wouldn't take a charge.
It did have enough juice from the charger that when the ignition was turned on I could hear the pump go.
Going back Friday with a good battery and a gallon of fresh gas to see if we can't get it started, it has not been driven in over a year.
2000 Tahoe Limited
Old 02-23-2015, 05:09 PM   #8
kevinr1970
So I brought a good battery with me and it fired after three cranks (hadn't been started in at least a year).
Test drove it around the neighborhood, but I trailered it home since it was around 20 miles and didn't want a gremlin striking someplace between.
Got home started it drove it off the trailer, drove it to the gas station later that day and put some gas in it, shuffled the trucks around the back yard the next day.
Started and ran each time?
2000 Tahoe Limited
Old 02-23-2015, 06:07 PM   #9
SCOTI
SCOTI's Avatar
Pull the pumps out & check the fuel transfer hose between the pump & the discharge lines out of the tank. Very common to have a weak hose w/the ethanol in the fuel dissolving the rubber hose (not rated to be submersed in ethanol).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-24-2015, 03:48 AM   #10
Damien
Damien's Avatar
I bought a '87 Jimmy and was told the fuel pump was out, but the truck started and drove fine around town and one highway trip. The second highway trip the pump went out completely. I felt pretty dumb when I had to pay the $175 tow bill when I had a new Delco pump at home. The motor in the pump will develop a dead spot and banging on the tank jars the pump enough to get past the dead spot. As long as it does not stop in the dead spot it will function but it could still be worn out giving lower fuel pressure which will affect performance and driveability.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 02-24-2015, 10:22 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
check the power to the pump,I found a corroded cut in my wire over the wheel well.
after replacing the pump in my 87,and it still died
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Thread Tools
Display Modes
