Old 02-18-2015, 08:20 AM   #1
Mjminino
Factory Rear End
When I purchased my truck it was in such shambles and I don't know if a lot of stuff is 'factory', they did a $hit job on the front end converting it to a 5 lug, which I was able to get that figured out. I am about to purchase some Impala SS brackets from Captainfab to get rear disk brakes, and get the CPP 5X5 rear axle conversion for a 64. Well in all honestly, it just dawned on me, I don't know if I have a 1964 rear end or another later year (if they took the same front/rear suspension off of a later truck) Could you guys please help me out on figuring out if this is a 64 or not?
Mjminino is offline   Reply With Quote
Old 02-18-2015, 08:29 AM   #2
vince1
Re: Factory Rear End
Yes I would say it is probably a 64. In 66 (maybe 65) the panhard bar is shorter and attaches to a lug in the center section. The attach brackets on the frame would also be slightly different due to the different angles of the panhard bars.
vince1 is offline   Reply With Quote
Old 02-18-2015, 08:34 AM   #3
vince1
Although my wife would never let me get away with that, thanks for that idea of clean up in the shower. Maybe I can work something up like that outside to clean up a 66 housing I have.
Old 02-18-2015, 08:35 AM   #4
Mjminino
What size diameter gears should I be looking for? I unfortunately cant just look for "12 bolt" ring and pinion gears. Does anyone have any recommendations on brand and ratio? I am thinking on 3.42 with 255/70/15's to accommodate my 4L60E
Old 02-18-2015, 08:37 AM   #5
Mjminino
That is the spare shower in the basement that never gets used. That was funny
Old 02-18-2015, 08:51 AM   #6
vince1
Most common was 3.73. You can figure that out pretty easy now that the cover is off. 3.07 was less common. I've heard that between the two they are a different series like maybe a 3 or a 4 so take a different carrier or spacer or something but other than that my knowledge is almost nil. I would think that a 3.73 gear set would be almost ideal with an overdrive automatic but you are probably quite aware of tire size rpm calculators to get the ratio you are after.
Old 02-18-2015, 09:47 AM   #7
vince1
1971 and up? differentials are 5 lug and maybe about 1 1/2" wider (using the shorter panhard bar).
Old 02-18-2015, 09:50 AM   #8
Mjminino
Well I am looking at getting THIS.
meant for a 64' housing.
Old 02-18-2015, 10:15 AM   #9
60-66
60-66's Avatar
Careful, if that's a 1964 rear it should have coarse spline axles used in 63 64 only. You'll need to replace the entire center section as the pinion is also coarse spline and the side gears.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-18-2015, 11:04 AM   #10
Mjminino
I am replacing everything, using the CPP 30 spline axles, and something along the lines of THIS. (Eaton GM 8.875" 12 bolt Truck Posi + Ring and Pinion 3.73 + Mstr Install Kit)
I still haven't decided on what ratio to go with. using the "RPM Calculators" at http://wallaceracing.com/calc-rpm.php this is the information I have gathered.
(all of these with the 4L60E, 60mph highway speed, 29" tire) a 3.73 will give me 1,815 OD rpm, 3.55 will give me 1,728 OD rpm, 3.42 will give me 1,664 OD rpm, and last a 3.08 will give me a 1,499 OD rpm
The application of this truck is absolutely nothing but a cruiser for the ol' lady and I, maybe take it down the track a couple of times just to see what it runs and launching at red lights , but that is it. Literally a daily driver to take to car shows and go cruising in.
Old 02-18-2015, 11:08 AM   #11
Mjminino
So I guess I might have practically answered my own question, does that mean I want/should get the 3.08 gears? I want it to have some get up and go. Heard or read somewhere that the lower gears will mean it is the opposite of that, is that true?
Old 02-18-2015, 11:18 AM   #12
60-66
60-66's Avatar
I have a 3:73 posi behind a 454 TH400 63 short bed and its a blast to drive. If your going long distance an overdrive would be nice but 3:08 in my opinion will kill the go factor
Old 02-18-2015, 01:17 PM   #13
LVPhotos
LVPhotos's Avatar
Once again here is a chart to find sweet spot. I run 28" tire, 3.73 gear and .63 od
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-18-2015, 02:12 PM   #14
verdell
verdell's Avatar
I went from a TH350 with 3.73 to a 700r4 with 3.08 and its been ok. It'll still squeal the tires and does great on the highway but i think the way to go is with 3.42's. I'm saving up for a posi and that's gonna put me right where I want to be. Just a thought.
verdell is offline   Reply With Quote
Old 02-18-2015, 02:22 PM   #15
corvettejim1968
corvettejim1968's Avatar
i have 3:73 with a TH350 and I'm good up till about 75mph. if your doing overdrive 3:73 is the way to go in my opinion. in my 2nd Corvette it came with 3:08 gears and it was a dog in my book. then i did the 3:73 and really brought the car to life.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 02-18-2015, 02:34 PM   #16
NevEno
NevEno's Avatar
I bought the same posi you did from summit. I'm going to be running a 4l60e with 3:73 with a 28 tall tire. We'll see how it works. The rearend you have with that big a$$ panhard bar bracket kills running dual exhaust on the passenger side with the truck lowered.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 02-18-2015, 02:38 PM   #17
Mjminino
It'll only be a 5"drop in the rear. Using just springs
Old 02-18-2015, 07:57 PM   #18
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I was waiting to see a funeral notice after your wife killed you for the rearend in the shower..
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-18-2015, 07:59 PM   #19
Mjminino
Old 02-18-2015, 11:18 PM   #20
frankslagoon
if the backing plates are pressed on it's probably 63. that's probably not good for you if your gona put disks on the rear at some point. I have a small V8 with a overdrive and 3:73 . 28 in tires. if I was running lower tires and buying a third member I'd go for the 3:42
frankslagoon is offline   Reply With Quote
Old 02-19-2015, 12:43 AM   #21
Captainfab
60-66 Nut
Yes that is a '64 12 bolt. It has bolt on backing plates and the panhard bar mount on the passenger side axle tube. I would recommend 3.73 gears with a OD trans. Of course that will also depend some on your engine, how it is built, and what you expect from your truck.
Old 02-19-2015, 11:45 AM   #22
Mjminino
You guys are toooo cool!
Old 02-19-2015, 12:40 PM   #23
Jeff La
I was kinda thinking the same thing
Jeff La is offline   Reply With Quote
Thread Tools
Display Modes
