Old 02-19-2015, 01:39 PM   #1
par4tom
Which year trucks have the 4 hole heater access plate???
I am in the process of installing a Vintage Air system, and just got off the phone with Vintage Air on a problem I am having with the heater access plate. The one I have from them has three mounting holes yet my 1961 truck requires a bigger plate with 4 holes.
The guy I spoke to, swore up and down that all of the 1960 to 1966 trucks use the same three hole plates and that I'm losing my mind. No sense arguing with him at this point...my fiance says I'm losing my mind too!!!
Here is the problem and I'm hoping you can help me out...I don't know which year trucks actually use the 4 hole plates like mine and which use the 3 hole plates that are smaller.
Can some of you gentleman help me out and tell me what year trucks actually used the 4 holes and which use the 3 holes...I'd like to communicate this back to Vintage Air.
Here is the photo of my 61 with the 4 hole plate...
tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 02-19-2015, 06:59 PM   #2
perro13
perro13's Avatar
Re: Which year trucks have the 4 hole heater access plate???
tom
From my experience 60-61 for sure
perro13 is offline   Reply With Quote
Old 02-19-2015, 07:09 PM   #3
60-66
60-66's Avatar
stock 1961 firewall plate
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-19-2015, 07:25 PM   #4
Trap62
Trap62's Avatar
Here's a shot of my 62.
Trap62 is offline   Reply With Quote
Old 02-20-2015, 12:57 AM   #5
cv65
cv65's Avatar
Hi, my 65 chevy c10 has 3 mounting holes,I have seen the ones like you have with 4 so your not nuts,I wonder if it has to due with heater type,mine is the cheap 1 knob ,some have more controls on dash,or maybe chevy vrs gmc ,or the cab change between 60-63 or 64-66,like to hear what it is,good luck
cv65 is offline   Reply With Quote
Old 02-20-2015, 01:15 AM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
/\ those guys covered it, but you can check out this thread too:
http://67-72chevytrucks.com/vboard/s...d.php?t=488618
lots of pics and info here as well...
you should get that vintage air guy to check out that thread, because the 60-61's are different, and it probably would not be hard for them to fab up a plate that makes their kit work with the earlier firewall,
it would be good to inform them so that people like you aren't frustrated when the product isn't an exact fit due to gm's production changes.
the 60-61 with a heater did have a reduction plate that spaces the hole down to one similar to the 62-66, but you only have that if your 60-61 originally had a heater....
Old 02-20-2015, 12:49 PM   #7
par4tom
I've never seen that reduction plate. My 61 truck did not have that item and it did originally have a heater...pretty cool info!
My Build Thread
Old 02-20-2015, 12:57 PM   #8
michael bustamante
michael bustamante's Avatar
i have a 4 hole heater plate and the upper long plate available if you need them
1967custom
michael bustamante is offline   Reply With Quote
Old 02-20-2015, 02:51 PM   #9
par4tom
Hi Michael...
Thank you for that offer. I have a couple of these plates as well.
Best,
Tom
My Build Thread
Old 02-20-2015, 03:21 PM   #10
dwcardfan
dwcardfan's Avatar
My 65 has the 3 hole. I thought in 64-66 had the 3 hole and earlier models had 4 hole.
dwcardfan is offline   Reply With Quote
Old 02-20-2015, 05:12 PM   #11
61 apache 10
61 apache 10's Avatar
1961 4 hole
61 apache 10 is offline   Reply With Quote
Old 02-20-2015, 05:54 PM   #12
jonzcustomshop
1961 crewcab
I have 2 with this plate, but it is the deluxe heater, maybe the cheap heater used something else?? my other 2 61's have the block off plate, and holes drilled where the cheap heater was added...not sure if either of those has an actual gm 61 heater...
Old 02-21-2015, 01:47 PM   #13
61K10
61K10's Avatar
my 61 has the org cheap heater with the 4 hole block off plate
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-21-2015, 02:02 PM   #14
1strong63
1strong63's Avatar
my 63 got 3 holes
1strong63 is offline   Reply With Quote
Old 02-21-2015, 11:11 PM   #15
BigDan3131
BigDan3131's Avatar
In the context of this discussion when switching to an aftermarket ac/heat combo it no longer uses your factory heater at all?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-22-2015, 11:47 AM   #16
par4tom
No...the vintage air system replaces the factory heater...
My Build Thread
Thread Tools
Display Modes
