Old 02-20-2015, 05:13 PM   #1
DogueParamour
Newbie needs help regarding '67
Hey all,
I'm new to the forum and new to C10's and had some questions for the veterans of this board. I have an opportunity to pick up a '67 stepside 6cyl manual from a friend of mine for $4k. I'm attaching a few pics for reference, but my main question is, is this a good truck to start with for the price?
My intentions are to swap the bed, drop in a 5.3l with auto trans, disc brakes, some suspension and interior work to make it a DD.
Any comments, suggestions, warnings, etc. are welcomed! Thank you!
DogueParamour is offline   Reply With Quote
Old 02-20-2015, 05:21 PM   #2
Wrenchbender Ret
Re: Newbie needs help regarding '67
Looks like a great buy to me. I had a 70 for a long time. It was the best running, driving truck I ever had.
Wrenchbender Ret is offline   Reply With Quote
Old 02-20-2015, 05:35 PM   #3
Greasey Harley
Greasey Harley's Avatar
Originally Posted by DogueParamour View Post
...My intentions are to swap the bed...
$4000 should buy you a decent short-wide truck, but this $4000 truck will need another $1000-$2500, to become a fleet side, unless you already have a different bed.
Sweet little stepper though.
Greasey Harley is offline   Reply With Quote
Old 02-20-2015, 05:54 PM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
Body looks pretty good.
I would replace that mickey mouse Grant wheel. W/o power steering those are hell to pull around parallel parking and in tight spaces. Also they can just pull off of the steering column at the worst times. The stock 16.5" wheel gives you way more leverage.
Three on the tree saginaw. The L6 is either a 250 or 230, but Alpine Green paint is unusual. I thought only the early 292s were Alpine Green, 250s were blue, but all motors were Chevy Engine Orange by '67.
'67s have no ACC position on the Ignition Switch. Also when you pull the light switch all the way out the parking lights go out. This is normal.
I think 4 grand is a little high, but that may be right for your market.
I 've had my '68 C/10 Stepside since 1973, so I know they're good trucks.
Good luck, and welcome to the board.
Old 02-20-2015, 06:05 PM   #5
1968aj
had to go outside and make sure my truck was still here.
1968aj is offline   Reply With Quote
Old 02-20-2015, 06:06 PM   #6
dubds10
Stalker Nate
Since it's all original it seems with an inline 6 and a stepper, I'd say $2-3gs should get it in your area. $4gs is a bit high for it not being a fleetside, but it looks fairly solid. Any rust issues underneath?
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 02-20-2015, 06:45 PM   #7
Mock1
Its not all original, 67 didnt come with lights in the fenders. Why is there only lights on the drivers side?
$4K? Wow, nice if there is no rust. But a lot for somebody fixin to hot rod it. Maybe ok for So.Cal.
I just gotta get out here and do it, why?
Cause nobody will do it for me...
Mock1 is offline   Reply With Quote
Old 02-20-2015, 06:47 PM   #8
dubds10
Stalker Nate
He doesn't have any lights in the fenders. That last pictures is of 1968j's truck lol
Old 02-20-2015, 06:48 PM   #9
michael bustamante
michael bustamante's Avatar
yup thats a nice truck, some parts have been changed but not for the worse exactly, column is different, mirrors are not 67 but those are cst door panals.. thats a plus! i like it. id go 2500 good running
1967custom
michael bustamante is offline   Reply With Quote
Old 02-20-2015, 07:04 PM   #10
Mock1
Oh, dang. My bad.
Old 02-20-2015, 07:53 PM   #11
swamp rat
swamp rat's Avatar
As long as all the rust repair was done correctly to the cab which i assume is the reason for the primer than yes its a pretty darned good start for a project, especially for a shortbed project. Then again, being a california truck maybe it has had no cancer and was a canadate for just getting painted?
Have you checked to see if the VIN on the frame matches the VIN on the cab? Vin # is behind the driver front wheel on the frame, driver door jamb on the cab. Also verify the SPID on the gloove box door too. Have you checked to see if the frame was cut down behind the cab and shortened? or if its an origional short bed truck?
If it is what it appears to be then i wouldn't want to pay any more than $4000 for it as it is, primer hides the real story, i'd prefer to be less than $4000 so try and talk the seller down, but if you can afford it it is a great starting point.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Thread Tools
Display Modes
