Old 08-25-2003, 10:01 PM   #1
method2mymadnes
method2mymadnes's Avatar
350c trans question
I have an 86 with a 305 & a 350c tranny. A while back the torque convertor starting intermittenly locking up at very low speeds. Now it doesnt lock up at all. Does anyone out there know anything about the lockup circuit on these transmissions?
Thank you, thank you very much!!!
method2mymadnes is offline   Reply With Quote
Old 08-26-2003, 05:26 PM   #2
method2mymadnes
t
t
t
Old 08-26-2003, 06:17 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Could be the lockup solenoid.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-27-2003, 02:12 PM   #4
method2mymadnes
t
t
t
Old 08-27-2003, 02:58 PM   #5
swervin ervin
If the solenoid went to ground at times it wasn't supposed to, this would cause the intermitent lockups at lower speeds. Then if it went to ground and stayed, it might blow a fuse. Check your fuses. If it is blown, replace the solenoid.
Old 08-31-2003, 02:01 PM   #6
method2mymadnes
Fuses are good.
Do you know where the voltage for the lockup is supplied from?
Old 08-31-2003, 02:14 PM   #7
gmtrucksaddict
ECM
unplug the solenoid at the tranny, go get a new solenoid, it may not be easy to replace it, i would just unplug it and call it done
gmtrucksaddict is offline   Reply With Quote
Thread Tools
Display Modes
