02-27-2015, 12:33 PM | #1 |
1972 C10 Headlights
What suggestions does anybody have for upgraded headlights?
02-27-2015, 01:09 PM | #2 |
Re: 1972 C10 Headlights
Have you upgraded your alternator yet? A higher output alternator and a new wiring harness does wonders with halogen bulbs.
Other than that. Here are a couple options: www.amazon.com/dp/B000FKIURK/ and www.amazon.com/dp/B00BQX2BT8/ |
02-27-2015, 01:20 PM | #3 |
Not really an upgrade, but I went with the tri-bar headlights for a different look vs your typical seven inch headlight.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
02-27-2015, 01:28 PM | #4 |
Thanks and the alternator is on the "to do" list. I just got the truck a week ago so I am open to all suggestions
02-27-2015, 01:34 PM | #5 |
I like those lights that have led strips in them. I just don't know if they last long
1969 Chevy c20(Miss Hackjob) |
02-27-2015, 01:34 PM | #6 |
70+ ( Old Skool Club )
Check out this thread. I had the harness on my last truck and just ordered one of these. If you had one of these harnesses on and a set of headlights with Silver Star bulbs in them that should be all the headlight you need for a regular use truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=660350
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-27-2015, 01:54 PM | #7 |
The Older Generation
Jeep Wranglar JK lights.... Do the relay upgrade also. http://67-72chevytrucks.com/vboard/s...d.php?t=641553 LockDoc
02-27-2015, 02:40 PM | #8 |
US Army Veteran
Here's a link to a write up I did last year, using Hella lenses and Xenon bulbs. Amazing difference and have been very pleased.
http://67-72chevytrucks.com/vboard/s...7&postcount=12
1972 C10 Highlander - The making of a daily driver |
02-27-2015, 03:47 PM | #9 |
Thanks for all the input.
02-27-2015, 05:40 PM | #10 |
I have the Hellas and they are awesome. Interent says the Cibie is better, but I'm not one to say. Get the Hellas for $35 each on Amazon. The Cibie is $45.
(I have one H4 Hella and one Cibie that came on my 240Z. Planning on buying one of each again to get two more pairs!) I really like the flat front look and glass lens of the Hella. I used the bulbs that came with them. I also have them in my '52 M38A1, my '79 CJ5, and a set in the box for my '69 Camaro. As you can tell, I'm sold. I bought the smaller high/lows for the '44 jeep and will figure out what combo I need to get them in the Jimmy as well. Great upgrade for not much $.
Thread Tools | |
Display Modes | |
