02-28-2015, 12:46 PM | #1 |
what is this bit on my heater for?
Never paid much attention to it as this is my first Chevy truck, but there is a round bit like a flag pole holder on top of my heater.
Last week Martin (mjh1965) and Rian (grizz1963) came over and gave the truck a once over. None of us know what that bit is or what it does. My truck is a '64, their's are a '65 and a '66, but neither of their trucks has that bit on top of the heater box. What on earth is it? |
02-28-2015, 01:10 PM | #2 |
Re: what is this bit on my heater for?
Never seen that before. My guess is something a PO added to maybe use as a prop rod holder for the hood.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab |
02-28-2015, 02:39 PM | #3 |
Looks like you got yourself a custom hood holder upper! made from the head of a floor mop,just cut a short piece of mop handle to hold hood up,Its called Yankee ingenuity!
02-28-2015, 02:57 PM | #4 | ||
If I recall correctly, it is also hinged.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
02-28-2015, 04:28 PM | #5 |
Senior Enthusiast
My guess is also that it is some type of bracket that originally connected a wooden handle to some type of mop or broom head. I agree it’s too far back to serve as a hood prop, but maybe it was used to hold up a sign or small flag that identified the band during gigs. My guess is the only one that identify what it is for, would be the person that installed it. I’ve never seen anything similar on another 60-66 heater.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-28-2015, 04:50 PM | #6 |
I think it's to prop up the trap door to clean debris off the heater core...
03-01-2015, 01:37 AM | #7 |
60-66 Nut
Neither that piece or what appears to be an additional cover plate are original GM parts.
03-02-2015, 05:34 PM | #8 |
You guys don't know what ur talking about.
"That's a nick nack Patti Black, give the frog a loan".
"Life is too short to drive a boring vehicle". Later, Wayne |
03-02-2015, 06:46 PM | #9 |
Chevy addict
Silly me, I thought it was a pistol holder
03-03-2015, 01:50 PM | #10 |
I'm agreeing w/the Cap'n on this one. PO used whatever he could find & utilize to easily fix his problem. Thinking he needed less/more heat or blow from fan to go into a particular location inside cab. If it worked, he probably only had to adjust [or remove] it twice a year to stay better warmed or cooled or defrosted, as called for at the particular season.
Just think: in our region, a comfortable ride beats sweeping many times over! And we won't even mention vacuum cleaning! Sam Try removing it and see what difference it causes. Then we will all know. Last edited by luvbowties; 03-03-2015 at 01:54 PM. Reason: more suggestions |
Thread Tools | |
Display Modes | |
