02-28-2015, 08:06 PM | #1 |
1962 chevy pickup master cylinder problem
I have installed a new master cylinder, slave cylinder, and all break lines on my 62 chevy. The problem is that when I try to bleed the breaks, it engages my slave cylinder. I'm a missing something here? Please help..thanks in advance
02-28-2015, 08:14 PM | #2 |
Senior Enthusiast
Re: 1962 chevy pickup master cylinder problem
It sounds like you have the wrong side of the master hooked up the clutch slave cylinder. These aren't dual master cylinders in the conventional sense. I believe the passenger side is for the clutch, and the drivers side is for the brakes. They are single individual master cylinders housed in a common casting.
Good luck, and welcome to the forum!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-28-2015, 08:18 PM | #3 |
So you have a dual master cly. with a push rod from the brake pedal to the brakes and a push rod from the clutch pedal to the clutch. if your saying when ya push on the brake pedal it pumps the clutch slave cly.?
02-28-2015, 08:19 PM | #4 | |
02-28-2015, 08:24 PM | #5 |
Thanks markeb01 will try swapping my lines and see what happens
02-28-2015, 08:31 PM | #6 |
Senior Enthusiast
02-28-2015, 10:11 PM | #7 |
Fixed!!! Thank you so much guys..God bless
Thread Tools | |
Display Modes | |
