Old 03-05-2015, 08:53 PM   #1
Sim6
Sim6's Avatar
Factory rear end
So I was looking at my rear end, driveline and where it connects to the tranny. There are no u joints! How does this flex with the suspension? Is it possible to use the rear end with a th350 trans? Thanks
Jeff
Sim6 is offline   Reply With Quote
Old 03-05-2015, 09:25 PM   #2
Henry50
Henry50's Avatar
Re: Factory rear end
The drive shaft is enclosed, the u-joint is on the front of the torque tube.
You can use that rear end with a th350, but you will have to pull the torque tube and swap in a 55-62 Chevy truck pumpkin. Then you would need to weld leaf spring pads on the rearend, and have a drive shaft built.
Henry50 is offline   Reply With Quote
Old 03-06-2015, 06:01 PM   #3
Rambow
Rambow's Avatar
Just curious, but why would you have to weld leaf spring pads on?
Its already set up for the factory leaf springs, right, or is that to get the pinion angle re-set?
_____________________________________
Ben R.
1953 Chevy 3100
Classic Seat Restorations -Preventing me from working on my own projects since 2009!
Rambow is offline   Reply With Quote
Old 03-06-2015, 06:46 PM   #4
1project2many
With the torque tube removed, there is no "link" to prevent the axle from pivoting up on the springs.
This axle has overload springs attached (overloads are on top) but you can clearly see the bracket attaching the main spring to the axle and it shouldn't take much to see how the axle can pivot around that bracket.
1project2many is offline   Reply With Quote
Old 03-07-2015, 01:38 AM   #5
Hawkerdriver
Hawkerdriver's Avatar
I just dropped my driveline today to pull the I6 for the 5.3 swap. took me a few minutes to figure out how to get to the u joints. Hadn't seen that style before.
Hawkerdriver is offline   Reply With Quote
Thread Tools
Display Modes
