Old 03-06-2015, 03:37 PM   #1
Jimjific
Jimjific's Avatar
CPP Brakes Squeak
Hello,
Has anyone installed CPP disc brakes and then had them squeak? I installed mine around Christmas and they worked great but now the passenger side squeaks. They work fine but it is annoying. A friend of mine has the same issue with a recent install of CPP brakes on a 64. More importantly has anyone figured out a way to stop them from squeaking?
Thanks,
Jim
Thanks,
Jim - 69 Short Step CST 350 AC/PB/PS
- 69 Short Step 307 Man Column/PS
Jimjific is offline   Reply With Quote
Old 03-06-2015, 03:59 PM   #2
First c10
First c10's Avatar
Re: CPP Brakes Squeak
My sons 70 LWB truck has Mcgaughys and have been on about a year and they are starting to squeak. So I plan to change the pads. not sure if this helps just wanted to let you know its probably not just CPP....
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-07-2015, 01:21 AM   #3
RManson
Pull the pads off and put some anti-sieze on the back sides where the caliper piston touches the pad and anywhere else it looks like there may be metal-on-metal contact. This is usually the culprit and not the pads. It has to do with the pads vibrating against the caliper piston when pressure is applied.
Try it out, see if it works, and let me know. It's always worked for me (my new CPP brakes squealed after a few weeks and this solved it). Since then, every brake install gets this treatment and no mo' squeakin'.
RManson is offline   Reply With Quote
Old 03-08-2015, 05:12 PM   #4
Jimjific
Jimjific's Avatar
RManson,
DO you use any special brand or just a brake pad anti squeak that you get from an auto store. I will give it try now that we are finally above freezing again in NY.
Thanks,
Jim
Thanks,
Old 03-08-2015, 05:39 PM   #5
Rod Run
Rod Run's Avatar
It has nothing to do with CPP, but probably the install. Did you use any anti-squeak stuff when you put them in? Not that I ever do, but some people seem to need that stuff.
Also, what type of pads are you using and did you follow the bedding in procedure 100% properly?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-08-2015, 09:21 PM   #6
Jason Banks
Jason Banks's Avatar
Here's what I use - http://www.amazon.com/gp/product/B000CINV88 http://www.amazon.com/gp/product/B000CINV88
Jason Banks is offline   Reply With Quote
Old 03-08-2015, 11:44 PM   #7
BigMike
BigMike's Avatar
^^^ Exactly what I use, great stuff..
BigMike is offline   Reply With Quote
Old 03-09-2015, 02:42 AM   #8
mechanicalman
Originally Posted by Jimjific View Post
Hello,
Thanks,
Jim
I've tried many remedies over the years for brake squeak, I've used mixtures that soak the pad, coat the backsides, rubber bushings between the caliper bolt and the pad, etc., they all have their effectiveness some better some worse but have never seen a real permanent fix.
It's the nature of the beast, IMO.
However, I installed new rotors and ceramic pads on my wife's Malibu, and it hasn't squeaked since.
mechanicalman is offline   Reply With Quote
Old 03-09-2015, 03:52 PM   #9
RManson
I use the same plain ol' anti-seize that I use for hardware and such.
Thread Tools
Display Modes
