Old 03-08-2015, 04:28 PM   #1
yoshi
yoshi's Avatar
AD headlight switch
I purchased a non o/e headlight switch, my lights suddenly went off so I turned the knob a little & it came back on. Now the lights keep going off even flickering. It's a bit dangerous desperately fiddling with the switch trying to get the lights back on when they go out. Anyone else had this problem? I see the genuine ones don't have a knob fo you have to buy them seperately? Any recommendations where to get 1 from? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 03-08-2015, 06:35 PM   #2
Race.it
Race.it's Avatar
Re: AD headlight switch
Are you running the lights through relays?
1954 Chevy 3100 currently original.
Race.it is offline   Reply With Quote
Old 03-08-2015, 06:39 PM   #3
yoshi
yoshi's Avatar
I think there is relays in the EZ wiring loom, I'll have to check
yoshi's 49 project
Old 03-08-2015, 06:58 PM   #4
Race.it
Race.it's Avatar
I know my loom does not have relays, have read the old original switches could deal with no relay as only 6v but the 12v need a relay for more reliable operation (this was from a mustang owner)
Maybe why your switch is dying?
You can get the knobs from many resellers in the U.S., prob fresh farm, and top speed in UK also.
Old 03-08-2015, 07:00 PM   #5
yoshi
yoshi's Avatar
Ok I'll ask EZ via email, thanks
yoshi's 49 project
Old 03-08-2015, 07:02 PM   #6
Race.it
Race.it's Avatar
My loom had a relay for horn, hazards and indicators
Old 03-08-2015, 07:08 PM   #7
yoshi
yoshi's Avatar
Email sent, await a reply tomorrow. If I need to fit one where the best place to wire it in?
yoshi's 49 project
Old 03-08-2015, 08:41 PM   #8
OrrieG
OrrieG's Avatar
I mounted a power block on the side of the battery box and ran the power wire with a fusible link to relays mounted on the radiator support, driver side. Details are here http://67-72chevytrucks.com/vboard/s...&postcount=802 I ran one circuit and relay for the high beams, one for the low in case one failed I would have the other set. I would replace the light switch, something inside is loose/shorting and is going to fry your wiring harness (best case) or burn the truck to the ground (bummer).
OrrieG is offline   Reply With Quote
Old 03-09-2015, 11:53 AM   #9
Apachemike
Apachemike's Avatar
Sounds like a bad switch to me
Apachemike is offline   Reply With Quote
Old 03-09-2015, 02:38 PM   #10
yoshi
yoshi's Avatar
Yeah just got reply from EZ 'Replace switch. if you can get them to come back on by fiddling with the switch then that is a bad thing' called supplier he said he'd swap it for another.
yoshi's 49 project
Thread Tools
Display Modes
