Old 03-12-2015, 11:47 AM   #1
65standard
65standard's Avatar
Outer rocker welding question
Anyone know if the outer rocker gets spot welded down to the inner rocker along the door gasket area? Mine were too far gone to know where the welds would be.
U
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 03-12-2015, 12:05 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Outer rocker welding question
Yes they do !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-12-2015, 12:18 PM   #3
65standard
65standard's Avatar
Thanks Gary. I'm going to weld it in right now.
I don't see why anyone would complain about these classic parts rockers. The fit is superb and the price is unbeatable. All of my patch panels are spot on
Old 03-12-2015, 12:36 PM   #4
CUSTOM/10
CUSTOM/10's Avatar
The patch panels now are much better than the use to be. I once tried putting repop rockers on ( 20 yrs ago ) and they were just horrible. Luckily back then you could still get them from the chevy dealership. I used Triplus rockers on my current project and the fit great !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-12-2015, 12:40 PM   #5
CUSTOM/10
CUSTOM/10's Avatar
Hey !
I strongly suggest you hang your doors and get them alined before welding your rockers on !!!! If you haven't already !!!
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-12-2015, 08:07 PM   #6
65standard
65standard's Avatar
Thanks for all your help. Right side rocker is done. Now off to the left side rust repairs. Then the bed will have to come off to replace the cab corners.
I didn't set the door first, but I took careful measurements before I cut the old one out. It worked out fine on this side. The other side is all gone and I will have to set the door on to make sure the rocker is at the right height.
Old 03-12-2015, 10:44 PM   #7
briank
Nice work, you dont mess around. Im just north of you, when can I drop mine off?
briank is offline   Reply With Quote
Thread Tools
Display Modes
