Old 03-14-2015, 01:49 PM   #1
Malamute
Malamute's Avatar
After searching, I still have a ball joint question
Any preferred brand? I found Moog upper and lowers on Summit:
http://www.summitracing.com/parts/mo...del/c10-pickup
These are for factory A-arms on a '69 C10 and I will be installing ECE 2.5" drop spindles. I just want to make sure I'm ordering the right parts first.
Thanks.
Malamute is offline   Reply With Quote
Old 03-14-2015, 03:06 PM   #2
c10vortec
c10vortec's Avatar
Re: After searching, I still have a ball joint question
I used the same MOOG ball joints on my winter project with 2.5" drop spindles. I also purchased MOOG springs, control arm shafts, and tie rods.
The lower ball joints pressed in nicely on my stock 72 arms. I bought them on recommendation from other build threads here.
I can't vouch for their durability because my truck is still sitting as a bare frame, but everything fit nicely and was stronger than stock
Dalton
-1972 C10 LS swapped SWB conversion- http://67-72chevytrucks.com/vboard/s...d.php?t=657591
-2004 Chevy 1500 swb daily driver
c10vortec is offline   Reply With Quote
Old 03-14-2015, 07:11 PM   #3
Malamute
Malamute's Avatar
Thanks.
Old 03-14-2015, 07:13 PM   #4
hugger6933
Moog will do you better than fine. I trust in them. Jim
hugger6933 is offline   Reply With Quote
Thread Tools
Display Modes
