Old 03-16-2015, 04:30 PM   #1
Brave71
Prop valve bleed?
Replaced leaking prop valve...do I need too bench bleed master again? Didn't loose much fluid.
Brave71 is offline   Reply With Quote
Old 03-16-2015, 04:42 PM   #2
88Ironduke
Re: Prop valve bleed?
I would say you shouldn't have to bench bleed the master cylinder but a 4 wheel brake bleed is in order.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 03-16-2015, 04:57 PM   #3
Brave71
Thanks for the help!
Old 03-16-2015, 09:03 PM   #4
hugger6933
No bench bleeding needed but you will have to bleed all 4 wheels. Start with the one farthest from the master cylinder. Then work your way back going from the farthest to the closest in order. [just in case somebody is looking that doesn't know] Jim
hugger6933 is offline   Reply With Quote
Thread Tools
Display Modes
