Old 08-27-2003, 10:13 PM   #1
jmanz69
Careful, they attack...
jmanz69's Avatar
Posi rebuild kit?
Anyone know where I might be able to find a rebuild kit for my posi carrier? The new frame I got had a posi rearend, but there was some water in it, so I am having the rear rebuilt. I wanted to get a kit to do the carrier. Any ideas?
jmanz69
jmanz69 is offline   Reply With Quote
Old 08-27-2003, 11:07 PM   #2
chiphayes
randys ring and pinion,1-800-292-1031ext5569, the guys name is ken,he just helped me with the rebuild of my 12 bolt,and the parts he sent me fit perfect,i had zero problems,and i felt like they were very resonable
chiphayes is offline   Reply With Quote
Old 08-28-2003, 06:37 AM   #3
jmanz69
jmanz69's Avatar
can you give an approximate cost?
Old 08-28-2003, 02:49 PM   #4
chiphayes
call him and ask,its free.i bought a detroit locker,install kit and new gears,was just over 500 bucks.if oyu just need the rebuild kit im sure it will be nothing that expensive
Old 08-28-2003, 03:47 PM   #5
jmanz69
jmanz69's Avatar
I called them today, the price for the parts was:
Clutch kit - carbon Fiber: 71.39
Sring Pack - 400lbs: 48.37
Spider Gears - 121.00
Shims for side gears: 32.35
Not a bad price to rebuild a posi. That wil do everything if you only have a case to start with.
Just thought I would let everyone know.
Old 08-28-2003, 04:07 PM   #6
boraxman
Keepin an eye out
boraxman's Avatar
For 289.00 on Ebay you can buy a new Eaton posi unit. Search "truck Posi"
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 08-28-2003, 05:10 PM   #7
jmanz69
jmanz69's Avatar
It will cost about $30 to have it shipped to you, those things are heavy!!! don't forgt to add that into the price.
Old 08-28-2003, 05:32 PM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Hey just showing other options
ZIP 91351
Old 08-28-2003, 08:49 PM   #9
crazy longhorn
Fabricate till you "puke"
I went through a local driveline shop.....it been a while, but the parts ran $145-150. That was stock replacement clutch pack(steel), 400lb spring kit, & the spring plates. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-28-2003, 08:55 PM   #10
jmanz69
jmanz69's Avatar
I stopped at the local ring and pinion shop tonight on my way home from work. Guy told me it would be cheaper to buy a new diff. I asked why, since a new one costs around $350. He said by the time you buy new spiders ($200 from him) and the rest of the parts it would be cheaper. I think I have decided not to let him work on it. I might have him pull everything out (seals and bearings) from the housing, but I know I can find someone to build it cheaper than that. Gotta shop around, that's all. He must not have wanted my business, although his shop did not look so full that one more job would be too much. Oh well
Old 08-28-2003, 09:10 PM   #11
crazy longhorn
If you need spider gears, the guy probably told you "square"....by the time you tax the parts you have listed, you will be close to 3 bills......I would spend the extra $50 for a new unit Just my thoughts, good luck, crazyL
Old 08-28-2003, 09:46 PM   #12
jmanz69
jmanz69's Avatar
they guy at randys told me $121 for the spiders, and the guy at the local shop told me $200. If I get them from Randys there is no way I would pay $80 in tax. That's like 40%! I'll continue to shop around. I left messages at a couple other places nearby.
Thread Tools
Display Modes
