Old 03-23-2015, 10:28 AM   #1
1moretoy
Hex style adjustable tie rod sleeves
Morning guys,
I was working on the front suspension of my truck over the weekend and was installing my qa1 5251 tie rod adjusters. Seems like a lot of people here use them with no issues. They measure 4-7/8 in length and the factory ones are 6" I believe. Problem is when installed there is only about an inch or so of threads of the tie rod screwed into them. Is this enough you think? I have looked around and can't find longer hex style adjusters. Truck is a 70 c10 with narrowed porterbuilt arms.
Thank you
1moretoy is offline   Reply With Quote
Old 03-25-2015, 10:14 PM   #2
1moretoy
Re: Hex style adjustable tie rod sleeves
Anyone have any info on this?
Old 03-26-2015, 01:20 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I think board vendor Pro Performance and Porterbuilt, both, makes a specific tie rod adjuster for the narrowed Porterbuilt a-arms.
Keith
Convert to disc brakes.
Old 03-26-2015, 02:02 AM   #4
Pro Performance
Pro Performance's Avatar
Yes, we do make an adjuster for both narrowed and standard applications. Right now, we only offer for the 71-87 C10's, since they use a different 11/16 thread.
http://www.azproperformance.com/Alum...71-87-C10.html
- Travis
Pro Performance is offline   Reply With Quote
Old 03-26-2015, 08:11 AM   #5
earl84
Don't know about the hex adjusters, but an inch of adjustment will move the wheels quite a bit.
earl84 is offline   Reply With Quote
Old 03-26-2015, 09:40 AM   #6
1moretoy
I think there is a little miss communication. Being that the hex adjusters are shorter there is only 1" of the tie rod threaded into the adjuster. I was worried there wasn't enough thread engagement. Is 1" enough?
Old 03-26-2015, 11:14 AM   #7
lolife99
lolife99's Avatar
An inch of thread engagement on each side of the adjuster should be fine.
The jamb nuts will keep everything solid.
Keith
Thread Tools
Display Modes
