Old 03-24-2015, 04:18 PM   #1
forestb
forestb's Avatar
door jam wire looms
Has anyone installed a set of braided steel wire looms on there truck? If so, what is the best brand and what length do I need?
forestb is offline   Reply With Quote
Old 03-25-2015, 10:42 PM   #2
Joemomma1
Joemomma1's Avatar
Re: door jam wire looms
Are you sold on the steel braided? Is rubber not an option?
Joemomma1 is offline   Reply With Quote
Old 03-25-2015, 11:53 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Don't know anything about the metal ones, but I've used the rubber parts-store ones on other projects and they worked fine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-26-2015, 01:19 PM   #4
forestb
forestb's Avatar
I never even thought about using the rubber ones. The ones that I have seen look like I would have to drill a larger hole. Do you have any examples of the ones you are using?
Old 03-26-2015, 01:40 PM   #5
Joemomma1
Joemomma1's Avatar
My looms required a 7/8" hole. I was hesitant to drill such a large hole for one wire but felt if I left that wire exposed it would look worse. im happy with the result and feel it looks clean. They were included with the power window kit by nu-relics. I believe they will sell them separately.
Old 03-26-2015, 01:41 PM   #6
Joemomma1
Joemomma1's Avatar
Sorry about the big photos, I don't know why they come out like that.
Old 03-26-2015, 02:36 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The ones I've used from the parts store looked pretty much like those ^^
Old 03-26-2015, 04:23 PM   #8
forestb
forestb's Avatar
How do you like the power window kit? Would you get the same brand again?
Old 03-26-2015, 04:41 PM   #9
Joemomma1
Joemomma1's Avatar
Without a doubt. Bolt in with a lifetime warranty and built in the US. Definitely not cheap but I've grown to hate having to do something again because I cheaped out the first time. They sent the wrong spine type cranks but a quick no hassle phone call had them sent with a prepaid return label for the incorrect units.
Old 03-26-2015, 10:03 PM   #10
corvettejim1968
corvettejim1968's Avatar
i really like that. was it difficult to install?
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 03-27-2015, 07:44 PM   #11
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Just for reference, here is a pic of my braided wire loom guards.
They work awesome, and look great. I am not sure on the brand but I can try to remember to look for the package the next time that I go to work on my truck.
I know that I still have the package, as there were some extra parts for multiple apps.
The rubber ones that you have look like they will work great also...They look like an OEM style part.
Modges'66 is offline   Reply With Quote
Old 03-28-2015, 02:05 PM   #12
Joemomma1
Joemomma1's Avatar
Not at all. You may need to power them up to adjust the regulator. With the screws they provide with the cranks it seems they're supposed to be attached from inside the door going out to the crank. If you need to remove the crank for any reason you would have to completely remove the regulator/motor assembly. I just picked up some longer screws and used some quick nuts. The switches are threaded, pulling to the door when attached with screws from inside going out but attaching from the outside in required the quick nuts. I had to remove the lip on the crank hole with a dremel to attach the clips. Compared to what you've been doing this should be a breeze.
Old 03-28-2015, 02:28 PM   #13
Joemomma1
Joemomma1's Avatar
What you have is what I was considering because I didn't want to drill a large hole. Braided would have been the choice if I had billet accessories or silver paint, like yourself, but I'm going for a more OEM look. I know it's not OE anymore but you know what I mean.
Old 03-28-2015, 03:02 PM   #14
Modges'66
Modges'66's Avatar
Yours still look good though!
Old 04-03-2015, 04:49 PM   #15
forestb
forestb's Avatar
Do you remember the length of the ones you have? I see them in an 11in and 18in length.
Old 05-26-2015, 04:31 PM   #16
forestb
forestb's Avatar
Where are you all running your wires after they enter the door jamb. I can not see any openings on that part of the jamb.
Thread Tools
Display Modes
