Old 03-28-2015, 11:12 AM   #1
SayBye
SayBye's Avatar
60-66: who has the cheapest bag setup that works?
who on here has done the cheapest bag setup on a 60-66 truck? Maybe you didn't use the parts you should have, didn't buy the good bags, bought a slow compressor, etc. I'm not looking to lay frame or anything crazy, basically just replace my cut springs with some bags and rock it like that: factory front end, no frame work, etc. At one time I had seen someone was selling a 500$ kit for these trucks, however i believe I can do it cheaper than this but that's an idea of what I'm wanting to spend...
SayBye is offline   Reply With Quote
Old 03-28-2015, 01:27 PM   #2
tinydb84
tinydb84's Avatar
Re: 60-66: who has the cheapest bag setup that works?
60-62 is different from 63-66. For the 63-66 you can cut your own top plate and weld your own cups in for the front. Similar set up for the back. Then run Schrader valves on each bag.
David
Instagram: myfabguy
Old 03-28-2015, 01:32 PM   #3
SayBye
SayBye's Avatar
63-66 is what I'm wondering about, mines a 64, didn't realize they were different!
Old 03-28-2015, 09:44 PM   #4
andrewmp6
The rear of your truck does it have the truck arms or leaf springs?
andrewmp6 is offline   Reply With Quote
Old 03-28-2015, 10:23 PM   #5
Rhino198073
I would contact Boris. Way2lo2
Rhino198073 is offline   Reply With Quote
Old 03-31-2015, 12:29 PM   #6
SayBye
SayBye's Avatar
arms n coil springs
Old 03-31-2015, 12:57 PM   #7
PGSigns
PGSigns's Avatar
Here is the thread with his kit. http://67-72chevytrucks.com/vboard/s...d.php?t=575686
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-01-2015, 01:36 AM   #8
andrewmp6
Yeah with coils all the way around you can get bags and brackets easy,The air management can be cheap if you don't mind manual valve/switches for it.Later on you can always upgrade that if you don't like it.You will want to have air gauges 3 will do they make a dual needle gauge so you can run one front and one rear left and right and a 3rd for the tank,The tank one can be in cab or on the tank either way just good to have it.
Thread Tools
Display Modes
