(I know this is in drivetrain, but need some replies fast!)
I'm in the process of installing my Caddy 500/TH-400 into my previously 292 I6/TH-350 '70 C/10. The trans mount from the caddy cross member doesn't look like it'll work with my truck cross member. For reference, the motor/ trans. came out of a '76 Coupe Deville. The tranny is a long tail shaft BOP TH-400. Questions: 1. Is there any difference between tranny mounts for a 350 vs. a 400? 2. Can I just unbolt my 350 mount, put it on the 400, and relocate the crossmember? 3. What tranny mount do I need to use? |
Fabricate till you "puke"
I think you will find the mount to be "universal", but you will need to relocate the crossmember. There are 3 different lenghts on the 400 turbo, & mounts are position different for each. Try this link on lenghts.... http://www.tciauto.com/tech_info/trans_dims.htm I need to rephrase that, the aftermarket mounts are slotted, & should fit either a 350 t or a 400 t. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 08-28-2003 at 08:23 PM. |
its all about the +6 inches
I dunno Al, the one on my Caddy 400 is totally wierd.
I have no answer for the question though. |
Its been a while since i have been under a caddy.....I take your word for that "odd" mount on the Caddy ,Andy
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 08-28-2003 at 11:22 PM. |
Yup. It's something like 4 or 5 inches bolt to bolt.
That's one reason I have a Pontiac tranny in mine. |
Thread Tools | |
Display Modes | |
