Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-29-2015, 08:55 PM   #1
amashal
amashal's Avatar
Positive wire melting
I noticed the other day the small wire off the positive battery terminal to the junction block was warm to the touch. Went driving today and noticed it got hot enough to melt the connector. See pic. I'm not good with electrical so what are some things I need to check to fix this? Any help or suggestions are appreciated.
amashal is offline   Reply With Quote
Old 03-29-2015, 09:51 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Positive wire melting
Are you running a larger Amp Alternator or stock?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-29-2015, 09:57 PM   #3
amashal
amashal's Avatar
Stock externally regulated alternator. It's a 71 blazer. I recently did the headlight relay upgrade with instructions off the site and everything with that seemed to go well. Lights are brighter than before.
Old 03-29-2015, 10:18 PM   #4
71meangreenc10
Well,
Since that is the case, I would see if it is the original wiring and maybe it's time for a new front harness. Corrosion can build up in the wiring and cause resistance and then you get hot wires. Also check to make sure you have good grounds.
I have cut some red wires apart and they were full of blue corrosion, not good.
Headlight upgrade shouldn't have done anything if it was wired properly, in my opinion.
Also check your voltage at the battery when running to ensure that the regulator is not over charging.
Smitty
71 C30 Wrecker
Old 03-30-2015, 11:12 AM   #5
_Ogre
_Ogre's Avatar
i am not familiar with ''new'' truck wiring
that location would be where the fusible link would be
could that be a fusible link starting to go?
shop air compressor timer
Old 03-30-2015, 01:29 PM   #6
michael bustamante
michael bustamante's Avatar
what is that yellow plastic thing in the wiring thats melted? any chance it grounded out?
nows a good time to put a fuseable link on there
1967custom
michael bustamante is offline   Reply With Quote
Old 03-30-2015, 01:37 PM   #7
amashal
amashal's Avatar
Should a fusible link be there? The yellow melted plastic thing is just a butt connector. I will check voltage this afternoon when I get home from work.
Old 03-30-2015, 01:45 PM   #8
michael bustamante
the butt connector prob caused resistance and heated the wire up. you should use a fuseable link there if possable but i dont know what amperage. im sure someone here will let you know
1967custom
Old 03-30-2015, 01:50 PM   #9
cdowns
cdowns's Avatar
those cheepy Walmart connectors cause more problems than they fix/// look around for high quality connectors preferably ones that you solder to have the jobs done right
Old 03-30-2015, 03:51 PM   #10
starterman99
starterman99's Avatar
If it was hot and melted only at the connector that indicates high resistance at that connection. If the wire burned insulation all the way down to the junction it is a problem further down, but from the picture it looks like only the connector.
1950 5 window
starterman99 is offline   Reply With Quote
Old 03-30-2015, 04:34 PM   #11
amashal
amashal's Avatar
Yeah it was only melted at the connector. Wiring looked good where I soldered in a new fuse link. I warmed it up and drove around for 10-15 minutes and the wiring doesn't feel hot. I probably will look into rewiring soon just for peace of mind. Heres the readings I got after driving. 13.98 volts at battery and 14.7 at big wire on back of alternator. Do those numbers sound good? And thanks to everyone for the help.
Old 03-31-2015, 11:28 AM   #12
michael bustamante
#s sound good good at the battery, glad you got it going again
1967custom
Thread Tools
Display Modes
