Old 03-31-2015, 09:45 PM   #1
tranz am
tranz am's Avatar
making 7 hole adjustable trailing arm brackets
Hey everyone, been a while, but I'm back on my project.
I decided to start this thread because I have been unable to find brackets for my trailing arms that suit my adjustment needs. I am also running NASCAR trailing arms which incorporate a mono ball bushing and a slightly wider bracket it s necessary to run them. I figure some of you might find this interesting or helpful.
heres where I started.
I have decided that it will be stronger with 8 holes instead of 6. I have upgraded the hole size to 7/16 and will be using fine pitch grade 8 hardware.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 03-31-2015, 09:50 PM   #2
tranz am
tranz am's Avatar
Re: making 7 hole adjustable trailing arm brackets
Here I make a jig to keep the hole in the same spot.
My build thread
1969 GMC SWB
Old 03-31-2015, 09:56 PM   #3
tranz am
tranz am's Avatar
Here is the odd sized box tube im using. 3 1/2 - 1/4 thick.
Here I have carefully laid out and marked the holes. This takes a while I might add.
My build thread
1969 GMC SWB
Old 04-01-2015, 09:20 AM   #4
bbcmudtruck
Looking good so far! Please keep the updates coming.
bbcmudtruck is offline   Reply With Quote
Old 04-01-2015, 11:18 AM   #5
tranz am
tranz am's Avatar
Thanks! Will do.
My build thread
1969 GMC SWB
Old 04-01-2015, 07:20 PM   #6
tranz am
tranz am's Avatar
I'm curious what some of you think about a radius bolt pattern on these brackets vs. the streight pattern ive designed.
I'm still kind of leaning towards the straight pattern. It would seem the axle location would determine the optimum placement of the radius curve dependent on spring height and how high or low the axle is in the frame to begin with. It seams trying to design it with a radius is kind of a shot in the dark without knowing this variable.
just curious about opinions here. I'll be uploading more pictures soon.
My build thread
1969 GMC SWB
Old 04-07-2015, 06:31 PM   #7
tranz am
tranz am's Avatar
Here are some more pictures.
I started over with a new tube because the original tube had a manufacturer defect that bowed the center sections inward.
My build thread
1969 GMC SWB
Thread Tools
Display Modes
