![]() Join Date: Dec 2012
Rochester 1bbl Carb bushings
Hello everyone, I cranked the truck up on this beautiful day. The Carb links around the linkage and the front bottom. A local carb shop said they could fix it if they had the bushings
Where can I find the best quality bushings? I found Mikes Carbs but I wanted other opinions Thanks
1971 GMC Sierra 1959 GMC 100 |
![]() Join Date: Oct 2005
Re: Rochester 1bbl Carb bushings
Generally when gas leaks (links?) out the throttle shaft the carb is flooding.
Why would it be flooding?
I meant "Leaks" for some odd reason I typed "Links"
Everything has been replaced but the Float
It leaks near the bottom of the carb, at the front at the brass shaft. When I press on the accelerator linkage it squirts gas out of it I am about to just buy a $325 rebuilt carb that has had everything done to it
Hello,
in the past i had the same problems with my carburetor, One time needle and seat were full of dirt Second time the float control was not good adjusted. I also took parts from Mike. Good qualitiy and very fast delivery (about 4days to Germany) ;-) |
Rochester B throttle shaft bushing repair! http://www.jalopyjournal.com/forum/i...air%21.802290/
Try this link. I did a bushing repair a few years ago.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
I am about to just buy another carb that has been professionally done
Thread Tools | |
Display Modes | |
