Old 04-06-2015, 08:18 PM   #1
Patrat
Junior Member
Headers for LS3 in a 59 with TCI ICS
I have tried two different sets, today the Thorley 324Y, nothing seems to allow a good setup for the steering shaft. Has anybody done this setup and found a set that works?
Patrat is offline   Reply With Quote
Old 04-06-2015, 10:25 PM   #2
t-tung
Re: Headers for LS3 in a 59 with TCI ICS
I've got some TSP truck headers on a 5.3 in a 57 and clearance is decent. https://www.texas-speed.com/p-3410-t...evygmc-v8.aspx these are the ones I have but if I had to do it again, these look like they'd give me better clearance. https://www.texas-speed.com/p-4150-t...8-2wd-4wd.aspx I'm not sure when I'll be in San Antonio but I'd let you bolt it up if you're interested.
t-tung is offline   Reply With Quote
Old 04-07-2015, 07:56 AM   #3
Patrat
Junior Member
Thanks T-Tung, those look similar to the ones I tried first http://www.summitracing.com/parts/ps...make/chevrolet
Just trying to make the steering shaft less complicated, but looks like I will need three u-joints and a support bearing.
Let me know when you are in SA and I will show you what I got.
Old 04-07-2015, 08:13 AM   #4
t-tung
That's what I'm going to have to do. They have some mid-length headers that I'm sure would work but I wanted full length headers. How about these? https://www.texas-speed.com/p-4164-d...-use-only.aspx
Old 04-07-2015, 11:05 PM   #5
Patrat
Junior Member
It may not be as bad as I thought, this is the Pacesetters mocked up
Old 04-07-2015, 11:17 PM   #6
t-tung
Hard to tell from the angle/pictures but it looks like the ones I have may give you a lot more room. They're swept back quite a bit more from what it looks like. Hard to tell though
Old 06-13-2015, 11:34 AM   #7
djracer
djracer's Avatar
TTung how low do yours hang below the frame? I need a set for my little brothers truck but it sits pretty low.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-13-2015, 12:01 PM   #8
t-tung
Kinda low but not terrible. The driver's side hangs a little lower for the crossover.
Thread Tools
Display Modes
