Old 04-10-2015, 03:58 PM   #1
1moretoy
headlight switch bezel?
Hey guys I'm in need of some help. How do I screw on the headlight bezel with no threads? Do I have the nut on backwards or am I missing something? This is what I have currently. The switch came with my american autowire harness. And I think I need something like the second pic.
1moretoy is offline   Reply With Quote
Old 04-10-2015, 04:10 PM   #2
john
member #16
john's Avatar
Re: headlight switch bezel?
Yes you need the adapter.
john is offline   Reply With Quote
Old 04-10-2015, 04:12 PM   #3
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: headlight switch bezel?
The peice in your hand is mounted to the metal dash. When you put the dash itself up to it it will stick out and you screw the bezel on it.
Some aftermarket dashes don't use it though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-10-2015, 04:13 PM   #4
1moretoy
Know where I can get one?
Old 04-10-2015, 04:25 PM   #5
john
member #16
john's Avatar
teeitup has alot of parts for sale, check his ads in the parts forum.
Old 04-10-2015, 04:56 PM   #6
FirstOwner69
FirstOwner69's Avatar
Does this help? Best picture I have on file.
FirstOwner69 is offline   Reply With Quote
Old 04-10-2015, 05:31 PM   #7
1moretoy
The one in the hand isn't mine. I found that picture on the forum. I think I need that style nut.
Old 04-10-2015, 11:28 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Only problem is that adapter may not fit the switch in your picture unless it is actually a stock type switch......
LockDoc
Leon
Thread Tools
Display Modes
