Old 04-11-2015, 06:43 PM   #1
chazz
chazz's Avatar
Radiator help.....
Newly purchased 63. Need some serious help with getting the radiator (right)!
As you can see from photos, shroud in front, shroud in back...incorrect mounting......WTF ! I would like some help with a correct size, shroud or no shroud, mounting? new from, hoses from trans, it has a small cooler tie wrapped to the front of the radiator now.......any comments and ideas greatly appreciated.
350, automatic.
chazz is offline   Reply With Quote
Old 04-12-2015, 01:35 AM   #2
Captainfab
60-66 Nut
Re: Radiator help.....
That is the small I6 radiator for the 230/250 engine compounded by the fact that the small block has the long water pump. That fan shroud is something cobbled on there from another vehicle. The shroud between the radiator and the radiator support is factory for the I6 radiator. What you will need is a V8/HD I6 radiator that sits on top of the radiator crossmember instead of down between the frame rails. You will also need the lower saddles to bolt onto the crossmember as well as the correct top support. Then a reproduction V8 fan shroud along with the factory side flashings to bolt the shroud to. Then you will need to move the fan back towards the engine. The fan should be only 1/3 to 1/2 into the shroud. I'm not sure if that is possible with the long water pump. I don't use long water pumps in these trucks.
Old 04-12-2015, 01:39 AM   #3
'63GENIII
'63GENIII's Avatar
Not exactly sure what you have there. Im not very familiar with that set up. I think that the original may have looked like a 55 gallon drum thats had about 10" cut off and installed for the shroud. I got a fiberglass one from repop places. I think it may have been for a '65? It's fiberglass and needed a little bit of trimming especially for the 21" fan. Mine doesn't have the thing that yours has in front of the radiator either though. Theres a lot of gaps that are going to be letting much needed cooled air out instead of through your radiator.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-12-2015, 01:43 AM   #4
Captainfab
60-66 Nut
The original and aftermarket V8 fan shrouds for the '63-'66's are made of a fiberglass/composite material.
Old 04-12-2015, 10:07 AM   #5
'63GENIII
'63GENIII's Avatar
Ahh, thanks Captain. I do remember them being a little pricey and not wanting to modify mine!
Chris
'63 k15 long step
Old 04-12-2015, 11:08 AM   #6
chazz
chazz's Avatar
Thanks all....What im getting is, I need a correct radiator, mounted in the correct location, and a correct shroud, also a short water pump. ANY advice or recommendations on a new rad, size, etc.... I thought the pump was a short one?.....Any advice on best place for radiator?
I want to do this right. Big thanks to you guys.
Need list:
radiator
mounts
shroud
fan
water pump
power steering bracket, (because im changing the pump) ?
alternator bracket ??? ( pump change)?
belts-correct pulleys
ANY thing Im missing ???
Old 04-12-2015, 03:07 PM   #7
66Submarine
66Submarine's Avatar
Originally Posted by Captainfab View Post
That is the small I6 radiator for the 230/250 engine...
No, look closely; IMHO it looks like it might be the large/"V8" radiator wedged into the small radiator location.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-12-2015, 03:18 PM   #8
66Submarine
It also looks like a short pump to me.
Old 04-13-2015, 12:32 AM   #9
Captainfab
60-66 Nut
I stand corrected, you are right. Yesterday I did not see where they cut the frame to mount the bigger radiator down on the lower ledge.
It is hard to tell with the weird angle of the pics and limited visability, but you could be correct on the water pump as well. Typically when the alternator is on the passenger side, it is a long water pump.
Either way there is a gross mismatch of parts going on there. I think we need some better pics that show more of the engine compartment so that we can make a good recommendation.
Old 05-29-2015, 10:04 AM   #10
Justin@EntropyRad
Justin@EntropyRad's Avatar
Radiator/Fans/Shroud: http://www.entropyrad.com/1963-1966-...-radiator.html
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 05-29-2015, 10:01 PM   #11
DPowers
DPowers's Avatar
Correct set-up should look like this:
DPowers is offline   Reply With Quote
Thread Tools
Display Modes
