Old 04-19-2015, 12:26 AM   #1
hemi43
hemi43's Avatar
Advance adapter 50-0405 pictures needed
I will be installing a 4L60E and mating it to my NP 205 soon, but I want to machine my own adapter. I will be buying the 50-6900 output shaft because at $180.00, I can't really make it cheaper.
The price for the aluminum adapter however is quite steep especially living here in Canada, so I was hoping some member may have some close up pictures that would help me fabricate my own.
Thanks.
hemi43 is offline   Reply With Quote
Old 04-19-2015, 02:06 AM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Advance adapter 50-0405 pictures needed
I ended up thinking the same as you and folded my cards. Bought the entire kit from AA but thru Summit Racing. I decided the headache wasn't worth it. They spent the $$$ designing all these parts, I'd rather go the easy way and cross that part off my build list...
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 04-19-2015, 02:07 AM   #3
GMC-YA68
GMC-YA68's Avatar
Also - I'll get you any pics you want of mine. Let me know what you need.
-Keegan-
Old 04-19-2015, 09:22 AM   #4
hemi43
hemi43's Avatar
The dollar exchange right now is crap, and just to get the adapter and shaft will cost me almost $800 with brokerage and duty. Making the adapter itself will only take a few hours, but will save me almost $500 for that part alone.I have a CNC plasma cutter here at home, as well as a full machine shop, and enjoy making parts, so it will be a "win-win" situation!! :-)
I would love to see a rear picture of the adapter where it bolts to the transmission, and would also like to know the exact thickness of it.
Thanks.
Old 04-22-2015, 06:01 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
I know of at least one person that had to machine an AA adapter to fit...
Rich
1972 K5 Blazer CST Click HERE
Old 04-22-2015, 07:11 AM   #6
A1971Blazer
A1971Blazer's Avatar
Thanks.
I have the layout and bolt circle dimensions for the 4L60E transmission side in CAD.
I own a machine shop and I was planning on making my own adapter as well but I decided to use a NP241 transfer case when I discovered my 205 had a bunch of bad parts in it.
I never finished the design but I would be happy to send you the file for the transmission side for the 4L60E.
A1971Blazer is offline   Reply With Quote
Old 04-22-2015, 12:19 PM   #7
skorpioskorpio
Hmm, you don't per chance happen to have the dimensions of the trans side of the bellhousing for a 4L60E do you? I can't seem to get measurements close enough for Solidworks to take them by measuring hole centers.
skorpioskorpio is offline   Reply With Quote
Old 04-22-2015, 12:22 PM   #8
skorpioskorpio
Oh FYI, I'm trying to make an adapter to mate a 4L60E Bellhousing to a 4L80E pump.
Old 04-22-2015, 12:30 PM   #9
A1971Blazer
No sorry...I was at the other end..............I do have a spare bellhousing that I'm using in my mock-up. If you're not in a hurry, when I get it back out, I will set it up on the mill and locate the hole dimensions for you.
It's for an LS1 (has the top block mount hole at 12:00 position) but if I understand correctly, you want the hole pattern where it bolts to the tranny, not the block?
Thread Tools
Display Modes
