Old 04-27-2015, 10:53 AM   #1
revjames
Door gaping
I have tried to set the door I have mostly the right gab around the outside but the bottom corner seems to be getting out from the rocker panel about a quarter of an inch to a half inch too much how do you get this to suck in better? It's the bottom next to the cab corner
revjames is offline   Reply With Quote
Old 04-27-2015, 10:54 AM   #2
revjames
Re: Door gaping
I should clarify that when the door shut it's it won't shut all the way on that corner
Old 04-27-2015, 11:12 AM   #3
1963c-10
1963c-10's Avatar
Re: Door gaping
Looks like the striker plate needs to move in towards the cab.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-27-2015, 02:38 PM   #4
revjames
Re: Door gaping
Updated pic, I am going to try the striker player when it stops raining hopefully that will do it
Old 04-27-2015, 02:47 PM   #5
1963c-10
1963c-10's Avatar
Re: Door gaping
Striker plate will allow the door to close more inward to the cab. That should take care of your problem.
Old 04-27-2015, 03:05 PM   #6
revjames
Re: Door gaping
Yay that worked the only gap left to fix is the bottom by the rocker is gaped more on the cab corner side than the firewall side seems the door is slightly tilting up. I think my bushing are gone in the hinges because there is a lot of play
Old 04-27-2015, 03:15 PM   #7
1963c-10
1963c-10's Avatar
Re: Door gaping
Are there any shims under the lower door hinge? If so, I would remove them. That might bring the bottom in. I don't normally see shims here, but you never know.
You may have to massage the bottom of the door skin a bit to get it just right if that's the last thing to adjust. especially if its a donar door off another truck.
Old 04-29-2015, 10:16 PM   #8
racecougar
racecougar's Avatar
Re: Door gaping
There should not be shims between the hinge and the body, as the in/out adjustment is performed via the slotted bolt holes mating the hinge to the door.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Thread Tools
Display Modes
