Old 04-27-2015, 04:49 PM   #1
forestb
forestb's Avatar
cleaning rotors
My rotors have been sitting with a tarp over them and they have developed a layer of surface rust on the breaking surface. Can I just clean that off with a wire wheel?
forestb is offline   Reply With Quote
Old 04-27-2015, 07:53 PM   #2
VonDog
VonDog's Avatar
Re: cleaning rotors
You don't want to gouge them, I'd use steel wool.
VonDog is offline   Reply With Quote
Old 04-27-2015, 08:28 PM   #3
jayoldschool
Moderator
Re: cleaning rotors
Flap wheel on a grinder works perfectly, or, take them in and have them turned. Steel wool won't be tough enough. A D/A sander with coarse grit will work, too.
jayoldschool is offline   Reply With Quote
Old 04-28-2015, 12:36 AM   #4
GRX
GRX's Avatar
Re: cleaning rotors
How bad is the rust? A little will not hurt anything. Nothing preventing them from rusting up when sitting in the driveway for a couple weeks.
If it is just light, I would use 120-grit sandpaper in a sanding block. A good shop will put a similar non-directional finish on the surface to facilitate pad break in anyway.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 04-28-2015, 01:14 AM   #5
Captainfab
60-66 Nut
Re: cleaning rotors
You can soak them overnight or a little longer in vinegar. Then the rust should wipe off with a scotchbrite pad. Then neutralize them with baking soda water, dry and coat them with a light oil until you are ready to put them to use.
Old 04-29-2015, 11:52 AM   #6
forestb
forestb's Avatar
Re: cleaning rotors
These are the best photos I have of what they look like.
Old 04-29-2015, 04:16 PM   #7
spookylynx
spookylynx's Avatar
Re: cleaning rotors
dosent look that bad. couldnt you just take it up to 35mph and hit the stop button a couple times?
spookylynx is offline   Reply With Quote
Old 04-29-2015, 04:31 PM   #8
forestb
forestb's Avatar
Re: cleaning rotors
I was worried that would hurt the pads.
Thread Tools
Display Modes
