Old 04-29-2015, 06:04 AM   #1
4DSEVEN
4DSEVEN's Avatar
Give me the gears...
Alright currently running 373's but leaning towards 410's. I'm running a 383 stroker and don't really highway drive. Thoughts?
Just wondering who's running what and recommendations please.
4DSEVEN is offline   Reply With Quote
Old 04-29-2015, 08:20 AM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Give me the gears...
I personally and based on my experience would not run a 4.10 without an overdrive trans. My current set up is 4.11 with OD and sort of wish I had gone with 3.89, but I do have 505 CID to move the heap.
Speedbumpauto is offline   Reply With Quote
Old 04-29-2015, 09:46 AM   #3
Bad Apache
Bad Apache's Avatar
Depends greatly on your rear tire size as well. I'm a drag racer and I hate my 4.10's with 255/60r15's in my street/strip car. It lifts the front wheels about 5 inches in the air and goes like hell, but sucks if I have to go more than 55 for a few miles. The added rpm heats the oil rapidly as well. Your stroker should be a torque monster and blow the tires off at will as is. So long story short, unless you're running a very tall rear tire, I'd stick with 3.73's.
1958 Apache 454ci 4 speed
Bad Apache is offline   Reply With Quote
Old 04-29-2015, 10:21 AM   #4
solidaxel
solidaxel's Avatar
What is the 3:73 NOT doing for you ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-29-2015, 11:35 AM   #5
_Ogre
_Ogre's Avatar
i have to ask this too
can't imagine why unless your after bragging rights for the least gas mileage
if you ever want to go to a show you'll think twice because of the cost of gas
shop air compressor timer
Old 04-29-2015, 09:00 PM   #6
4DSEVEN
4DSEVEN's Avatar
I'm happy with the 373's but wondered if I am missing out on more grunt. Just a weekend toy so highways are next to none. The boys at the shop are trying to convince me given my use but I'm more than reluctant to make the swap. I kept asking myself the same thing "why".
Think I best leave it as is.
Old 04-29-2015, 09:56 PM   #7
tmoble
I'm going from a 3.73 to a 3.42 with a 200-R4 OD trans.
tmoble is offline   Reply With Quote
Old 04-29-2015, 10:40 PM   #8
imjeff
imjeff's Avatar
You should have plenty of grunt with a 383 and 3:73s.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-29-2015, 11:53 PM   #9
nvrdone
ive got a 327 with 3:73's & it smokes em at will. but not too bad on the freeway
nvrdone is offline   Reply With Quote
Old 04-30-2015, 08:47 AM   #10
solidaxel
solidaxel's Avatar
Make sure your ignition is in proper tune and your carb is also, there is a lot of horsepower in timing and jetting!
LS 3 4L70E
Old 04-30-2015, 09:53 PM   #11
57chevyman
57chevyman's Avatar
i have 4.11 gears with a three speed, no OD. my engine is a 1977 SBC 350. its fun to drive around the neighborhood, but i cant cruise at highway speed.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 05-04-2015, 09:02 PM   #12
pgf545
pgf545's Avatar
Richmond has this gear calculator.
http://www.richmondgear.com/index.ph...ion-calculator
Randy's Ring has this one.
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
And this one from Coast Drive line.
http://www.coastdriveline.com/htmlfo...lculator2.html
You can play around with the gear ratios using know variables from your truck. I have used the old Richmond (Coast Drive Line) one before.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Thread Tools
Display Modes
