Old 04-30-2015, 01:05 PM   #1
Get Down
Get Down's Avatar
I've been searching and to no avail
Can somebody be so kind to either post pictures or a link on how to the assemble the stock vacume motor link to switch, with the grommets and how the spring is attached. I've search this forum, Google online service manuals and all I find is upgrades and newer style. It's a 49
I would appreciate any and all help in the right direction. I know it's kind of a minor issue but one I would like to solve. Thank you
Get Down is offline   Reply With Quote
Old 04-30-2015, 05:00 PM   #2
Tomb23
Re: I've been searching and to no avail
Vacuum pump and fan
Tomb23 is offline   Reply With Quote
Old 04-30-2015, 06:08 PM   #3
OrrieG
OrrieG's Avatar
I am confused, I thought he was asking about the wiper motor?
OrrieG is offline   Reply With Quote
Old 04-30-2015, 06:14 PM   #4
Tomb23
? Maybe I was ?
Old 04-30-2015, 08:30 PM   #5
Get Down
Get Down's Avatar
Yes I'm looking to see how the spring and link arm attach to the switch and vacume motor with the new replacement grommets.
Old 04-30-2015, 10:42 PM   #6
OrrieG
OrrieG's Avatar
I think it is the same as the later TF. the transmission arm at the head goes down. The other end goes over the gromett and shaft. The spring ends goe in a slot in each shaft. I can't remember the which side goes on which shaft but the length of the arms should be a clue and worse case you will have to switch them. Make sure it works then install the wipers.
Old 05-01-2015, 09:33 AM   #7
Get Down
Get Down's Avatar
I think your right, I messed with it last night and figured the spring goes under the two clips on each shaft since they are elongated the same way. I put the link on with the grommets started the truck the wipers turn on but did not return. I' m hope that's because I didn't have the spring hooked up yet. I'll mess with it today and hope for the best! If I get it working properly I will give an update.
Thank you guys for your input. Appreciate it.
Old 05-01-2015, 12:59 PM   #8
OrrieG
OrrieG's Avatar
Do you mean did not park when turned off or would not make a full rotation when running?
Old 05-04-2015, 10:51 AM   #9
Get Down
Get Down's Avatar
They did park when turned off! While running they only went one way on, until I shut it down then they returned to off. Still haven't got the spring hooked up yet so not sure if it's fully operational!
Thread Tools
Display Modes
